Clutch issue
Ok.... Now go to the other side of the engine & take off the large side cover (with 5 screws) & tell us exactly what you see spinning when you roll the bike.
  • Like
Reactions: FOG
The big gear and the small gear and the clutch plate. I can hear the Piston pumping
If all those are turning, then there's nothing wrong with the clu!!!! (If you pull the clutch lever in, those shouldn't be turning)
If the piston is moving up & down too easy?, then you have a lack of compression... (which is a completely different issue from the clutch)!!
That's what I was starting to think. How do I fix the compression? Any ideas
Did you by chance have to put the piston and cylinder on? If so double check your work. It almost sounds like it doesn’t have rings on the piston.
You're no supposed to be able to turn the engine over with your fingers, there definitely something wrong.
Pull the cylinder off and see if the rings are broke, be careful with the bottom gasket and you can reuse it.
