this is with the motor not running the bike just sitting there I can push it freely without squeezing the clutchMaybe I'm wrong but that's how the other bike is that I built
The big gear and the small gear and the clutch plate. I can hear the Piston pumpingOk.... Now go to the other side of the engine & take off the large side cover (with 5 screws) & tell us exactly what you see spinning when you roll the bike.
If all those are turning, then there's nothing wrong with the clu!!!! (If you pull the clutch lever in, those shouldn't be turning)The big gear and the small gear and the clutch plate. I can hear the Piston pumping
That's what I was starting to think. How do I fix the compression? Any ideasIf all those are turning, then there's nothing wrong with the clu!!!! (If you pull the clutch lever in, those shouldn't be turning)
If the piston is moving up & down too easy?, then you have a lack of compression... (which is a completely different issue from the clutch)!!
Would that be like new rings or somethingThat's what I was starting to think. How do I fix the compression? Any ideas
It came all together I can see the rings through the carb portDid you by chance have to put the piston and cylinder on? If so double check your work. It almost sounds like it doesn’t have rings on the piston.
I agree Im new to these engines. I'm not sure how to fix it. But I'd like to try instead of replacing itYou're no supposed to be able to turn the engine over with your fingers, there definitely something wrong.
I think I should get a new Piston and rings and try thatI agree Im new to these engines. I'm not sure how to fix it. But I'd like to try instead of replacing it
Ok I'll post what I findPull the cylinder off and see if the rings are broke, be careful with the bottom gasket and you can reuse it.
Rings are fine everything looks normal inside. I don't get it. I ordered new rings just to tryOk I'll post what I find
