Clutch issue
Venice Motor Bikes
Mar 20, 2008
7,271
1,810
Los Angeles, CA.
Ok.... Now go to the other side of the engine & take off the large side cover (with 5 screws) & tell us exactly what you see spinning when you roll the bike.
  • Like
Reactions: FOG
Mars4
20
The big gear and the small gear and the clutch plate. I can hear the Piston pumping
Venice Motor Bikes
Mar 20, 2008
7,271
1,810
Los Angeles, CA.
If all those are turning, then there's nothing wrong with the clu!!!! (If you pull the clutch lever in, those shouldn't be turning)
If the piston is moving up & down too easy?, then you have a lack of compression... (which is a completely different issue from the clutch)!!
Mars4
20
That's what I was starting to think. How do I fix the compression? Any ideas
Greg58
5,353
2,575
Newnan,Georgia
Did you by chance have to put the piston and cylinder on? If so double check your work. It almost sounds like it doesn’t have rings on the piston.
Mars4
20
It came all together I can see the rings through the carb port
Mars4
20
You're no supposed to be able to turn the engine over with your fingers, there definitely something wrong.
I agree Im new to these engines. I'm not sure how to fix it. But I'd like to try instead of replacing it
