Clutch issue
Discussion in 'Instructions for Building and Repairing Motorized ' started by Mars4, Feb 9, 2020.
  1. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Just got new motor from eBay this is my second build. The bike rolls freely when I press clutch and release it. It always rolls freely. Removed all 3 sprockets to check the keys all fine. Still does the same thing not sure what to do
  2. gill vanderwerf
    gill vanderwerf Active Member
    Sep 9, 2019
    104
    31
    do you mean it does not engage the clutch?
  3. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    The clutch engages but when I let go it still rolls like it's engaged when it isn't
  4. Venice Motor Bikes
    Mar 20, 2008
    6,561
    343
    My first guess is that you might have the clutch cable too tight
  5. bairdco
    Aug 18, 2009
    6,545
    224
    Or you need to adjust the flower nut.
  6. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Adjusted it same issue
  7. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    I also disconnected the clutch cable completely and the bike and chain still roll
  8. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    I've tried loose, tight it still rolls
  9. bairdco
    Aug 18, 2009
    6,545
    224
    Check and see if the clutch plate is stuck to the pucks. Sometimes new engines kinda glue themselves together and you have to whack it with a rubber mallet or something.
  10. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Thanks I tried that also. Took the entire clutch apart checked spring and put it back together still doing it. The spring on the shaft was so tight loosened it. A little better but still rolls without pressing clutch
  11. Venice Motor Bikes
    Mar 20, 2008
    6,561
    343
    take the side covers off... roll the bike & figure out whats turning (& whats not) & report back here.
  12. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    All 3 gears
  13. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    3,923
    784
    If the small gear is moving and the engine is not turning over either the key under the gear is broke or missing, the compression should provide resistance to make the clutch freewheel.
  14. Greg58
    May 1, 2011
    3,923
    784
    This is very strange, I'll be watching to see what you find.
  15. Venice Motor Bikes
    Mar 20, 2008
    6,561
    343
    Post pictures of them!
    Greg58 likes this.
  16. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    I can turn the small great with my hand and it moves the Piston up and down.
  17. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Yes it is strange I'm at a loss not sure what to do. I'll keep at it
  18. Venice Motor Bikes
    Mar 20, 2008
    6,561
    343
    So is the piston going up & down when you roll the back wheel?
    You need to post some pictures because you're not making much sense.
  19. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    the sprocket that the chain is attached to is not supposed to turn unless you squeeze the clutch.mine turns no matter what whether you squeeze a clutch or let go of the clutch
  20. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Maybe I'm wrong but that's how the other bike is that I built
