Clutch issue
Discussion in 'Instructions for Building and Repairing Motorized ' started by Mars4, Feb 9, 2020.
  1. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    this is with the motor not running the bike just sitting there I can push it freely without squeezing the clutch
  2. Venice Motor Bikes
    Mar 20, 2008
    6,550
    330
    Ok.... Now go to the other side of the engine & take off the large side cover (with 5 screws) & tell us exactly what you see spinning when you roll the bike.
    FOG likes this.
  3. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    The big gear and the small gear and the clutch plate. I can hear the Piston pumping
  4. Venice Motor Bikes
    Mar 20, 2008
    6,550
    330
    If all those are turning, then there's nothing wrong with the clu!!!! (If you pull the clutch lever in, those shouldn't be turning)
    If the piston is moving up & down too easy?, then you have a lack of compression... (which is a completely different issue from the clutch)!!
    #24 Venice Motor Bikes, Feb 14, 2020
  5. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    That's what I was starting to think. How do I fix the compression? Any ideas
  6. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Would that be like new rings or something
  7. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    3,901
    755
    Did you by chance have to put the piston and cylinder on? If so double check your work. It almost sounds like it doesn’t have rings on the piston.
  8. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    It came all together I can see the rings through the carb port
  9. Greg58
    May 1, 2011
    3,901
    755
    You're no supposed to be able to turn the engine over with your fingers, there definitely something wrong.
  10. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    I agree Im new to these engines. I'm not sure how to fix it. But I'd like to try instead of replacing it
  11. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    I think I should get a new Piston and rings and try that
  12. Greg58
    May 1, 2011
    3,901
    755
    Pull the cylinder off and see if the rings are broke, be careful with the bottom gasket and you can reuse it.
  13. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Ok I'll post what I find
  14. Mars4
    Mars4 New Member
    Feb 9, 2020
    20
    Rings are fine everything looks normal inside. I don't get it. I ordered new rings just to try
