All the engines vibrate unless you are one of the lucky few that got a well balanced one. You have a better chance of winning the lottery though.
There should be a certain RPM range where the vibrations are nearly non-existent. That is known as the "sweet spot" and most folks just ride at that speed.
Above that speed, some vibrate so bad that folks are complaining of fear of loosing the fillings in their teeth.
The best way to combat it is to use a good quality spring seat and hand grips that will absorb the vibrations and not transfer them to your butt and hands.
Also, these vibrations are known for shaking loose all the nuts and bolts on the entire bike. Go over your bike after every ride and check them all. Don't tighten them unless they have come loose, you do not want to damage or strip any of them by over tightening them. Soon you will learn which ones rattle loose regularly and which ones are good for a while. Still check them regularly though, you don't want any unexpected surprises while out on a ride.
I am one of the believers in a product called Loctite. Some folks swear by it, some folks swear at it.
Loctite 242 Blue works very well.
Do not use Loctite on the factory kit screws and studs though. You need to upgrade to better quality hardware. The factory hardware can easily strip out the heads or snap before the Loctite looses it's grip.
SBP sells a great hardware kit at a very fair price.
http://www.sickbikeparts.com/catalo...ducts_id=43&osCsid=rbk3q31guvamv8kgacn25lks12
If the engine is not getting too hot or pinging, you don't have to worry about overheating.
A good "shade tree mechanic" test is to spit (or flick a
little bit water) on the outer cylinder head fins immediately after a good long ride. It should evaporate quickly. If it sizzles the engine is too hot.
After 500 miles you are good to switch to a 4oz/ gal. ratio (32:1).
Expect to adjust the carburetor a little as the fuel will now be slightly thinner with less oil in it and therefore flow slightly more through the fuel jets inside the carburetor.
