GearNut
The Mag rotor came apart? That is very strange.
If so it still should be not too difficult to remove if you can get the individual plates to align again. Remove the stator (charging coil) first. Trust me on this one, it makes things alot easier.
Before doing anything, mark the stator with a permanent pen to indicate which side faces out. It is all to easy to install it backwards and doing so will crush the wires against the engine case ruining the stator. When pulling the stator out you will be fighting the magnetic power of the rotor. It can be a pain in the butt.
Remove the nut from the shaft and use a battery terminal puller to pull the rotor off of the shaft. Battery terminal pullers are dirt cheap at alot of pawn shops and really not too expensive at auto parts stores.
