GearNut
zearo, If you are snapping bolts that means that a sideways stress is being applied to them.
They will only tolerate a stretching load.
Something is not right with the way the engine is resting in the frame and the bolts are getting loaded in the wrong direction.
joker, check out these threads.
Cylinder head fastner torque
Cylinder head lapping
Get a new head gasket, lap the head as shown in the second link, and bolt the head and new gasket back on with the correct torque as shown in the first link. Tighten them a little at a time switching from nut to nut in an X pattern until you reach the proper torque.
Ride it moderately for a 10 minutes, let it cool completely, then check for proper torque on the head nuts again. By check I do not mean tighten them even tighter than they were before but rather that they still are as tight as they are supposed to be. Over tightening them will cause damage.
Check the head nuts frequently until everything settles in then they should be good to go for a while. Always check them anyways as a part of a regular maintenance schedule.
