My experience has been that chains do not like to go fast if they are not in an oil bath. Most people running a dry chain primary do not put the miles in. The people I have known that ran high miles with a minimum of drivetrain maintenance were guys with belt primaries. The best deal for a dry system is a belt primary. Much can be learned from lawnmower racers about high hp and v-belts. Also low tooth counts as found on most modern clutches absolutely kill chains in short order. I think a belt primary with clutch on the jack shaft like the whizzer is the way to go. Maintenance becomes easy unlike on the engine you must change the spring to get a smoother lockup. But on the jackshaft after an approx 1.4 reduction you can run a stock mt clutch and it will lockup at the right rpm for our needs and keep the bike slim; could even shorten the crankshaft.Dan, I have cooked #41 and #35, neither one has meat to bother with. My recipe has shown some degree of durability and no slinging. My machine has no chain guards. O-ring chain would be nice.
Tom from Rubicon
Speaking of safety I know a lot of people (me) are older and need glasses when working with machine tools, do you were regular glasses or safety glasses? I have bi-focal safety glasses at every tool that you should wear them at. That way I don't have an excuse to risk getting flying debris in my eyes. I have dodged a bullet twice in my life and not lost a eye doing stupid stuff, I was buffing exhaust valves when I was about 20, I took off my glasses because it was too hot. No more than five minutes later a piece of wire came off the wire wheel and stuck in my eye, I could see it between my pupil and nose. I ran to the restroom of the machine shop and looked in the mirror, the wire was sticking straight out. Being young and stupid ( I'm old now) I pulled it out. Lucky for me it didn't have a barb on the end, I had blurred vision for several day but no damage.
A face shield affords some protection along with glasses or safety glasses. I've had to have steel taken out of mysimilar thing happened to me but a piece of metal was stuck in my eye would not come out, after some thinking under duress I found a rubber glove a magnet for picking up bolts stuck the magnet in the rubber glove and rolled around my eye and like 16 shards of metal came out my eye. Good trick I learned. View attachment 101137
