Best Engine Kit For Worksman Front Loader Tricycle With Ice Cream Vendor Set Up
Discussion in 'Motorized Bicycle General Discussion' started by ICE CREAM VENDING TRICYLE, Apr 19, 2010.
  1. ICE CREAM VENDING TRICYLE
    Apr 19, 2010
    I need max torque. No speed. Pictures and specs are avialable at worksman cycles web page, just google it real quick, I can't post links yet toonew :(. Tricyle has a Shimoto7 speed rear axel. I am usingit to sell pre packaged ice cream treats. Just need help gettin up gentle hills and across grassy fields...
  2. furament
    furament New Member
    May 31, 2009
    214
    ya i want one of thoes too
  3. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    I usually play the 2 stroke game... but to me this screams for a 4 stroke with the new shift kit...
    but you'll hafta ask the 4 stroke fellas 'bout that :D I suppose ya could go electric, dunno what range you'd want but you've prolly the room for batteries heh
    As for the links, it just takes a coupla posts more - welcome to the place!
  4. silverbear
    silverbear The Boy Who Never Grew Up
    Jul 9, 2009
    8,191
    12
    In a typical day would the motor run very often or for very far? This is like a helper motor for a bike you mostly pedal? Would it matter to you or to your state if the motor was gas or would it need to be electric? Is the front wheel a drum brake model? More specifics would be helpful in people making suggestions. Off hand, a front wheel pancake electric motor comes to mind since it doesn't take up any more room (just the batteries) and nobody would object to electric. On the other hand a small electric motor elsewhere would allow you to keep that great Worksman heavy duty wheel which likely has a locking drum brake on it. In another couple posts you can upload pictures and that would help, too. Interesting project which I'm sure can be done. What do you visualize? What would answer your needs, even if you don't know how to go about it yet?
    SB
  5. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    I think he's got to be talking about this:
    Worksman Cycles - Hot Dog, Ice Cream, Popcorn Vending Carts
    It's a trike with two wheels in front.
    I don't know a whole lot about ebikes, but I'd think an electric friction drive in the rear would be best. After that, a rack mount four stroke. Make sure you're using the right roller or sprocket size, and you'll get all the torque you want.
  6. longhair
    longhair New Member
    Mar 24, 2009
    232
    Put a two stroke, expansion chamber, match port both intakes, etc. But, more importantly- if your gettin that Ice cream Worksman bike..... I'd like two drumsticks and a strawberry 50/50 bar when you're in L.A.
  7. TerrontheSnake
    TerrontheSnake New Member
    Jun 1, 2009
    720
    This is just my 2 cents worth, I would go with a lifan or other brand 50cc honda clone with a 4 speed. I say this for a few reasons, #1 quality! these motors go through a more stringent quality control than a china girl. #2 the gears will help your low end power output if you gear it right. #3 if you are seriously going to do this professionally I don't think you want to have to tinker with it often or mess with mixing fuels, and last but not least I think if the bike is similar to the one pictured in the earlier post I just think it would be much easier to get mounted up. O and I would like 2 frozen snickers and some bon bons!
  8. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
    2 good humor chocolte eclairs here please...
  9. ZRTMWA
    ZRTMWA New Member
    Feb 23, 2010
    142
    Any 2 stroke should do fine with a 56T (tooth) rear sprocket or even a higher amount of teeth. Going up a hill with one of these would be death to a normal engine with a full cart of ice cream. This is the cheapest option. Four stroke could maybe be better but it's more expensive and would be a lot harder to mount on that trike.
    Now that I look more closely at the bike I'm seeing that any engine is going to be a PITA to mount. Your best option could be to try and rack mount a Chinese two stroke engine ( the same engine as described in my first option). Or you could rack mount basically any small engine, 2 or 4 stroke.
    Whatever you use in back, make sure it's a chain drive with a large sprocket and not a roller (friction) drive. I don't think you could get enough torque with a roller drive.
  10. Tad Bit Tipsy
    Tad Bit Tipsy New Member
    Jan 2, 2010
    478
    I think the problem here is not what engine, but where to put one. I have ridden one of these and the frame doesn't have enough room to fit an engine in it. Therefore I would go with a rear mounted 4-stroke from Dax and then just upgrade your rear spoke to a higher tooth. Stick with a multi-speed pedal drive, so you can pedal from corner to corner, then fire the puppy(engine) up when you need to move across town. 2 cents, L8R.
  11. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,650
    66
    Great idea Ice Cream. I visited their factory and asked about converting an ice cream bike into a hot dog cart. The CEOs answer was "Sure, we can do any thing" And he meant it! Really am a big fan and devoted customer of theirs. They do some great work.
    But to answer your question and more what I was thinking for the hot dog cart version, I am going with a Harbor freight 79cc rack mounted over the rear wheel. More then enough power, great engine and is ridiculous cheap. It's only draw back is it is big but rack mounted on a trike, don't matter much. Just my thunking and any of the suggestions will work for ya. Like the ewheel ideas. Could get a large solar panel. What are you gonna do for refrigeration?
    Again, great idea and best of luck. Please post how biz goes. I'm really curious.
    .flg.
  12. silverbear
    Jul 9, 2009
    8,191
    12
    Yes, I understand now, this has the single wheel in back and two up front. Sounds like some good suggestions and the Dax in back would be cool. Would you ever cruise along with this or is it strictly a creep along?
    Dan, I was thinking about your hot dog cart and wondering if a hot dog side car would work as something you built yourself. Fasteddy's sidecar frame would support anything. Ice box down low using dry ice and above it the grill stuff. Then the bike could be multi-purpose and detach from the hot dog side car. Frankly, a tubular shaped side car would be best...
    SB
  13. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,650
    66
    Very interesting thoughts SB. Hadn't thought about a sidecar. And think the Titan would fit the needs of a trike perfectly.
    Detachable is a great idea. Got me thunking trailer with ball and hitch setup.
  14. silverbear
    Jul 9, 2009
    8,191
    12
    On the reservation hot dogs are also referred to as 'tube steaks'. Hey, it's steak night! A trailer would be a really good way to go since it can all be home built and is pretty low tech. The bike itself will draw attention and instead of just asking questions about the bike they can talk and eat. Might also lead you to bike builds or motor sales at the same time. It sounds like a winning combination, frankly (did you get it this time?).
    In the old days there was bitter rivalry between the Ojibwe (Chioppewa) and the Lakota & Dakota (given the name sioux by the Ojibwa when asked by the Europeans who those people were. The Ojibwe said they were sioux which means "snakes" and unfortunately that is now the officially recognized name for the Sioux Indians). Anyway, the rivalry continues, but now in the form of jokes instead of war parties. The Sioux ate dog meat, much frowned upon by the Ojibwe so this story is a reference to that.
    His Saddle Stinks and Windy Boy had never left the reservation until the day they went to a big city. They wandered around some, more than a little bewildered at how different everything was and spotted a hot dog stand. Hot Dogs, it advertised. Looking for a taste of home, they both put their money down. Windy Boy unwrapped his and took a bite with some disappointment and asked his buddy, "What part did you get?"
    Not that this has anything to do with ice cream tricycles, but its hot dogs anyway. Kind of on subject.
    SB
    #14 silverbear, Apr 23, 2010
  15. Maxvision
    Maxvision New Member
    Jun 13, 2009
    551
  16. azbill
    azbill Active Member
    May 18, 2008
    3,367
    laff good one SB :) laff
  17. Humsuckler
    Humsuckler New Member
    Jul 28, 2009
    458
    that briggs and stratton engine is pretty solid, but where the **** is the exhaust supposed to come out?
  18. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    Go Electric!
    When dealing with food, people and slowly moving parking spots in park settings, electric drive is the way to go. Quiet, CLEAN, no hassling with fumes, engine noise, fuel/oil spills and dirty hands while handling food.
    A front hub motor would work. Lots of battery space on a tricycle.
    My bike had a range of 50 miles, so more than enough for an ice cream vendor in a park.
    #18 5-7HEAVEN, Apr 23, 2010
  19. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,650
    66
    Lol Sir! I hope to enjoy a cup of coffee with ya some day soon. Your my first pick for a member on the board of directors of "Frank~N~Footers" (I wanted to do a "frankly" joke here but got notun')
    .flg.
  20. silverbear
    Jul 9, 2009
    8,191
    12
    Hey Dan,
    We'll make our cup a virtual one and have it here at the forum. Glad you liked the story/joke. Even my Lakota friends thought it was pretty funny. I've found that generally Indian people have a great sense of humor and have always loved stories. I see that I mis typed Chippewa. Although Chippewa is the official name of the Ojibwa people it is not what they call themselves. They sound similar and the mistake in pronunciation is known to the Ojibwa as the white man's learning disability. The Cherokee call themselves Tsalagi, so somebody really had wax in their ears when they turned it into Cherokee. I don't know about the other tribes but would guess there are some big discrepancies. I also sometimes wonder how it is that the Lakota are in the Dakotas and the Dakota are in Minnesota. It's enough to make your eyes spin around. I am deeply honored to be a potential board member of Frank~N~Footers. Franks a lot! I'll have mine with chili & cheese...
    SB
