Ask a specific question
thanks kelly. hold on to it i am sure we will get togather this summer for a ride and i will get it then :D
I didn't get one either. My kit was so cheap I could bend the clutch lever with my hand. I didn't even put it on the bike.
No problem Cruiser, I'm sure we'll get together and ride, man am I itchin' for a ride. the snow is almost melted enough to get into my storage shed, after that its a quick tune up, some warm gloves and away with the wind(^).
Deacon, I would not reccomend the stock clutch lever for anything more than scrap. I use locking Pyrimid brake levers, they are used on adult trikes and can be ordered at any LBS for between $10-15 a pair...Kelly
the locking part interest me greatly and the price is what I have been paying for regular ones
What kind of speed are you guys getting with the stock Chinese 80cc kit and 44T sprocket ? I'm on a 24" bike and seem to be getting 20mph. Does a 26" make much difference ?
thanks
yes a bigger wheel makes a big difference. i am getting around 35 with a 40 tooth sprocket. when i had the 44 i was getting around 31 mph
Has anybody used the Honda GXH50? I want to use it on my next build and was wondering who has used and how well does it work.
thanks
There are those who swear it is not possible but I have seen 38-40 a couple of times on the flat, wide open. That was with a 44T, 26" 1.90 tires. Two different vehicles confirmed it. Not recommended.
I'm changing one to a 36T from thatsdax just to lower the cruise rpm.
I know that every now and then we have a questions that isn't urgent and doesn't require a long answer just a few simple words. So here you go my first question of that type.
Okay my engine is mounted almost perfectly vertical very little tilt. But some I have noticed are at about 45 degrees or more. So does that effect the carburator. If so how.
New to this.
I have a 70cc 2 cycle and bought a pull start for it but cannot get the nut and washer off the shaft in front of the magento because it keep's turning,tried holding the gear's but still turn's?
Do you know somebody that could help me.
Thank you.
sailor49618
[email protected]
Take spark plug out. Make sure piston is down a bit. Feed some clean flexible nylon or poly or whatever rope in spark plug hole. Turn engine now, until it tries to "compress" the rope. Rope trick.
Tried it and the shaft still turn's without the gear's or piston moving.
I cannot think of anything else to do but send it back??
Are you saying the main shaft turns and no piston movement??? Yikes. Are you watching it with a box end wrench?
If the shaft is turning and the piston and gears aren't then the rod is not connected and neither are the gears.
NEW QUESTION
Which would be easier to fit a friction drive wheel to, a trimmer motor or a blower motor.
