Ok LS614 , pictures for your enjoyment
. I decided to rebuild the bent rim that has been on the rear of the bike, the one that was in the videos so i put my skills to work and started lacing up a 48 spoke wheel , i have only done 36 and 68 spoked bikes before so this was a second time thing , i built the front wheel perfectly true, the back wheel is true but has a few small flat spots even when i spun the wheel up to 600 rpm you couldn't tell so it will be fine i got the rear sprocket already one , just a little bit more guys and she's done I havent thought of a name for it yet but if i do build the stretch cruiser im going to name it after my girlfriend of 3 years , Shelby, with an airbrushed pin up on the tank so ill have to get a new airbrush kit . the little lever on the side of the bike is for the choke. The cut up bike hub is the jack shaft support , i jumped on this and kicked it just to make sure it could handel a sudden jolt and i know not pretty on the mount , but it works , besides it will be mostly covered, today im painting it black with engine enamel and the tank should be dry from painting last night , repairing the damage i did to it. im still scrounging parts for the bike , copper tube , clear fuel line , but im still going to be short , oh guess what I found this morning on the side of the road ,..... the front halve of a dirtbike , just sawed in half , it has the speedo light wiring forks disc brake just imagine a dirtbike cut in half without the engine , what did i do ?? helped out my community and took it home
hahahaha and i took my bike to the closest hill and rolled down it , probably hit about 25 mph or so and just cornered like i was racing , where the pegs are now help with the handling so much before they where just too high for how low i had the seat ive been up for a little over 2 days just designing and working on my bike ( this is normal for me ) I'm going to chill in my room for a while then take my laptop out with me to the shop and work on the tank im going to drain it then mount it on the bike for now and i may have found out why my bike was a little hard to start, the spark plug cap was faulty , so i pulled one off of my numerous little engines i find all over , some are still in working condition , just need a little love nd care to get them running , that's all
