ok update guys, i clear coated the tank ,....but the @%^#% clear coat ate my pain, though im to blame i grabbed the wrong can , re painted the whole thing from bare metal and now the clear coat is drying. I found an issue with my carb , the cast metal was so weak that it broke off when i tugged on it only just , so i cut a thick washer from stock and made a plug for the carb where the fuel was supposed to enter through. I took my micrometer and measured some parts off of my scrap engines from over the years and found a small spigot and drilled a hole for it to go into , the problem is im using car fuel line, so i had to make an adapter , and i used what i had, rc car parts ,my diabetes test strip vials (type1) solder and anything else i could find , the end result looks like an external fuel pump to make it go ZOOM ZOOM lol but in reality its just a barb with a hole trilled into it with solder plugging it up the black vial was meant to be a second filter but one is good enough, so its now a mini holding canister for whatever. but it looks mean now. and i now have 157 $ to finish my project
i made a new much more pretty mount . but i had my angles off and i don't wanna cut it up again and redo it so imma' start from scratch again using l stock and whatever metals i have ( i attached a pic of my two guitars with my FUZZ nickname in the special lettering i came up with done with a sharpie)
