Dyno Mid-Drive Shifter Build
culvercityclassic
Well I am at it again, looks like I am hooked on the ebike way of life. I have picked some top shelf items for this build, almost have it as a roller...Going after the street tracker look and performance. Pictures to follow...
  • Like
Reactions: EZL
Dyno frame powder coated, hand polished motor mount brackets, drop-out extensions and drop out savers.
A couple more pictures of the build. Sturmey Archer 8 speed disk hub will get laced into the Felt alloy rim with 12g spokes.
It's a roller...
Waiting on battery to arrive... 52volts of Samsung 29e cells.
Thanks Norm.. This should be a fun ride. A couple updated pictures: upgraded motor mounts.
CulverCityClassics,
Thank you. That is a very impressive site. Their products are certainly reasonable and even more so with the discounts they are currently offering.
Made in the U.S. helps with the decision.
Steve
The nice thing is that they have a section for Sonders electric bikes with upgrades and replacement parts.
With all the Sonders bikes being sold I'm sure other makers will follow suit.
Steve.
I figured you would get to shifting electrics and love 'em.
Once you have rode many different gas powered bikes, their simple eloquence and simplicity as an e-shifter bicycle is hard not to love.
Just a note about the SBP kit's engine mount using the BB...
You made a cool fancy new plate set (well done) but is that ideal for your frame?
Though they are fine on most bikes, they always seem to be a pain in the butt getting the motor in place and spaced right, and the BB parts don't always have enough threads to fit it in and the BB to be on tight.
You can fashion in a motor mount direct to the frame anywhere you want and leave the BB out of it.
A piece of L metal and a couple of muffler clamps and you're set.
Did you say muffler clamps KC, I don't even use them on mufflers... lol
Heheh, cool parts.
attachment.php
I don't use muffler clamps on exhausts either.
I don't use them for their original squeeze 'internal tubes' together intention at all.
I use them as a tight transition form a round tube to a flat mount surface using the top side of the clamp brace.
~$1.25 around the corner at the auto parts store in whatever size I need.
What do yours cost?
You get a much better cost then I do, I pay under 10.00 for each one...but then again its the look and fuction I am going after. Your a builder/ seller so I understand cost.
The parts are starting to roll in, the shifter hub and the tracker bars... Battery tomorrow... I am ready to rock and roll and complete this bike...
The latest update: got all the parts to complete the bike now. Back wheel and rear disk setup are complete, working on the battery box and controller wiring. Super nice battery and charger setup....
I am using: 52v Samsung 30q 15ah pack. I plan to pedal most of the time, will be my primary ride with all this Los Angeles BS traffic to deal with...
