jackshaft kit
shiloh0
88
its great to see that jackshaft kit now available, im ordering one right away, anyone else planning on trying one out?dan
datz510
290
Mesa, AZ
Im working on getting one on my bike as I speak. Its a fantastic quality kit for the money. I can't wait to ride mine. :D
datz510
290
Mesa, AZ
Mine is an old Gary Fisher Aquila Mountain bike.. Mine has been a very interesting installation so far due to a number of issues with the design of the bike.
If you check out the Rotten Orange Gary Fisher build in the photo section, theres a whole thread about it with lots of photos. Here's a link:
http://motorbicycling.com/showthread.php?t=2308
For most bikes, this shifter kit is a pretty simple installation, but you can read about how i'm solving some issues that I came across solely due to the way my bike was built.
mechanickid
419
nh
where did you get your jack shaft kit? the only one i've found is $200!
looking forward to your reply.
lennyharp
431
6
18
Mesa Arizona
Datz and I both got the Sick Bike Parts Shifter Kit from Welcome to Sick Bike Parts and it has been a lot of fun to ride. At 200 dollars they are not making a lot on these kits and it would be very expensive to try to reproduce it without free use of a full machine shop. Then you still have to get the quality parts to make it all go and the design Jim and Paul worked out.These guys are the real deal when it comes to customer service and quality product.
hombremosqa
66
salt lake city
this seems like a good plan, but cost is a bit high dontcha think? also, how exactly does this work????
from looking at some of the vids on youtube, it looks like the jackshaft rides on the same sprocket as the bike chain. is this right? wouldnt it make it impossible to pedal???
Pablo
Dec 28, 2007
3,696
33
48
Duvall, WA PNW
www.sickbikeparts.com
so i guest they mainly charge you $200 for a front freewheel and 2 small sprockets and the bracket.
also for $200 one could also buy a new bike and engine kit.
Well actually there are three brackets and you get those items, chainrings, cranks, spindle, jackshafts, chain, chain tensioner,....well here's the parts list:
1 Crank L & R & Freewheel 1
2 Bottom Bracket Spindle 1
3 36t Sprocket 1
4 44t Chainring w/chain guard 1
5 5/8" x 5.25" Jackshaft 1
6 5/8" Bearings 2
7 5/8" Lock Collar 1
8 17t Jackshaft Sprocket 1
9 10t Jackshaft Pinion 1
10 5/8" Bearing Washer 1
11 Bearing Bracket L 1
12 Bearing Bracket R 1
13 6mm x 35mm Left Bracket Bolts 3
14 6mm x 30mm Right Bracket Bolts 3
15 6mm Lock Nuts 2
16 6mm Nut 6
17 6mm Washers 6
18 Bike Chain 1
19 Rear Motor Bracket 1
20 1 1/8" Muffler Clamp 3
21 Motor Bracket Spacer 1
22 6mm x 35mm Rear Bracket Bolts 2
23 6mm split lock washers 2
26 Clutch cover 1
27 Upper chain guard 1
28 6-32 T-nuts 3
29 6-32 x 1/4 screws 3
30 Jump Stop chain guard 1
31 5mm x 25mm sprocket bolts 5
32 5mm washer 5
33 5mm lock nut 5
34 6mm shim washers 3
35 3/16" x 3/16" sprocket key
And it's ready to bolt on for $179
Ghost0
763
Bellingham, WA
Well there is a little more than that. There are 86 individual items that make up the kit including the hardware, if you remove the hardware there are 23 major components.
dvddtz
162
Gulf Breeze, FL
Thanks Ghosto,you handled that much better than I would have.I just have to remember that the number of posts doesnt mean anything.David usflg
lennyharp
431
6
18
Mesa Arizona
This kit is one of the best $200.00 I have spent on my motor bike. I have spent close to $700.00 on a kit with plastic drive parts and was not impressed with it. This kit is a real good deal. Somebody is just complaining to spread discontent if they say this is a bad deal. I have over 1000 miles on my kit. I plan on collecting more miles and enjoying them.
NunyaBidness
1,062
2
38
memphis tn
after seeing the list of parts you get for $179 it does look better,but i still wouldnt pay that.
a transmission or performance muffler should not cost the same as a engine.
I'm sorry but in this case you are totally wrong. Compare the parts on your lil Chinese motor to the parts in the SBP jackshift kit. You will then see why I say you are wrong in this case.
lordoflightaz
296
Phoenix, AZ
Not to mention that you include the chain tensioner assembly in that new lower price.
OMG, I just thought of something you could do, even though I have never seen the actual chain tensioner.
lordoflightaz
296
Phoenix, AZ
Ever had to pay for the brake antilock device on a car? Might be the most expensive piece of equipement under the hood of a car and it does not even make the car go faster.
Russell
1,276
155
MA
After you ride your china and are able shift through the gears. you just won't go back to single speed even if you originaly though that the price was high. (I don't think the price is unreasonable) If you try to duplicate it and charge yourself $3.00 hr it will still cost you more.
