Need help! 140 spoke rims and installing the rear sprocket
Bwest
Hey guys, need some help here. Just a got a new bike and I mainly bought it because I loved the rims on the bike. The rims have 140 spokes and I really didn't think about how to install the rear sprocket before I bought it. Anyways, I have a pic of what it looks like below, but my main question is,
What the **** does a man got to do in order to get a rear sprocket on this damn thing?
Any advice or help is appreciated
Thank you!
I've never seen one on a M/B. But maybe it's been done
Have ya checked to see if a rag joint lines up with the spokes?
Kinda hard to figure without the wheel right in front of me.
Looks like you just might have to Fabricate a custom Rag joint and maybe change the sprocket mounting holes to make it work. Or give up your dream of a 120 spoke wheel
But maybe a member on this forum has done this with a 120 spoke wheel before and will chime in with information of how it's done
I've seen it done!
A stock 9-bolt sprocket can be installed on those wheels... (but it's not easy).
You're gonna have to spread the spokes apart to get the bolts through; but the hardest part is getting the inside rag joint in there & getting the hardware all threaded on!
As far as I know not posable, unless you bend and distort the spokes, rag joint are meant for 36 spoke wheels. Like wrench said unless you can figure out how to put really small bolts and make your own............Curt
I just got it. Ty
Unfortunately I can't pay $200
Would this work?
Sure that will work, But... there's a reason the Sick Bike Parts kit cost a little more.
It's Made in USA and it uses a White Industries Free Wheel. It's worth the extra $$
It can take a licking and keep on clicking
Installing 140 spoke rims and the rear sprocket can be tricky, but with the right tools and patience, you can do it! Make sure everything is tight and secure. Don't forget to double-check your work before taking it for a ride!
Did you look at the date of the thread or its last post? The thread is almost 3 years and 7 months old; nor has the OP been on the forum for more than 3 years. Hopefully @Bwest has figured it out by now. If he hasn't then it's probably best if he's given up.
