Cranbrook Springer Forked BTR YD100 Replica Build (without fabrication)
curtisfox
6,082
4,059
minesota
For China girl engine it is not necessary to cut bottom tube, It is your bike and build it the way you want. What I or others say is not always the way you want or like. LOL. Help is always good, its like why didn't I think of that, and you could always save the old girls frame for another build, or maybe instead of hole bikes just look for frames. That is a good video........Curt
Nightster
735
1,738
93
61
Texas
I understand, someday I’ll go for a four stroke motor and need more of a defined loop and bottom plate.
thanks again curt
been practicing my welding in my free time, sheet metal and steel tubing. And it still needs practice but getting better
Nightster
735
1,738
93
61
Texas
BTW, I was cruising eBay last night and found a 49cc China doll engine kit for $28.98, with tax $30.79.
as soon as I bought it, I thought of this website and buying another one lol. I went back to buy another one and they were already gone.
don’t know if I will use this motor on this build or not but I have one ordered
I believe it’s the upgraded motor with 8 mm bolts
  • Like
Reactions: fasteddy
Nightster
735
1,738
93
61
Texas
Well I got the bike!
the only identifying mark besides the serial number, is this sticker low on the seat post. 100th Anniversary Edition. But if it is, it’s missing the gas tank and the springer forks. It definitely does not have the stock forks on it. it has a hole on part on the frame where I believe a fake gas tank was once mounted.
anyway I believe it to be a 1995.
Nightster
735
1,738
93
61
Texas
Got her all stripped down with the exception on the reflector on the steering head. About to remove that and check the head size.
she’s looking different already but the seat has to move back for sure
thinking about cutting the top bar and supports off before heading over to my girlfriends house this evening. Do you all think the one bar is enough support? no plans to ride at this point.
  • Like
Reactions: fasteddy
fasteddy
7,476
4,965
British Columbia Canada
I usually plug one end of the tube and fill it with tightly packed sand. Pour a little sand in as you tap the side of the tubing with a hammer then ram the sand down hard with some round bar. Repeat until full and cap the end when your finished.
This will keep it from crushing when you bend it.
You may want to buy some round bar if you don't have any. It always comes in handy for using as a sleeve when joining two pieces of tubing.
The trick is to find something round that you can bend the tubing over to give you the right bend you want. Just so long as it doesn't crush when your bending. Get the tubing longer than what you want so you have the leverage to bend it. Clamp it in a vise if you can.
Hope this helps. The bike is looking good.
Steve.
Nightster
735
1,738
93
61
Texas
Steve.
Thanks Steve
And I appreciate the info. I think leverage will be the key for sure. The 1” tube I cut off is roughy .077” thick. I’m guessing I can find something comparable at Home Depot.
she’s coming along, seat and pedals gone too. Need to remove the chain, sprockets, etc.. also.
a little more grinding and then I can rough up the whole finish.
here’s where I finished tosay
Nightster
735
1,738
93
61
Texas
I also wanna angle the seat post at 90° towards the back, then 90° up again. How much of the seat post do I need to leave inside the center tube? Well I need to get some more 7/8” round tubing to add to it?
or I think I’ve seen them online but I can’t remember where.
  • Like
Reactions: fasteddy
