Only thing I did besides split kindling was pull the Brookes 190 from the Flyer to rethink the pitch control of the saddle mount. Weather here today, I should have been riding weather was very mild.
The weather here was pretty mild too just about 60 degrees and sun. I remounted that 20-tooth sprocket on the bike
to see how the newer drive belt works. I noticed just a little bit of slippage and a noticeable difference in takeoff speed.
I am thinking that the gear is too high and causes the belt to slip which is actually messing up acceleration and
letting it to top out on the CVT. I guess the CVT probably has run it's limit with the belt slippage on the drive pulley.
The old original belt slipped really bad and the newer belt from GoPowerSports is a better quality belt and even
so it would slip on the pulley. The gear gave a good cruise speed and there was plenty of torque for takeoff but
I didn't want to hammer the throttle with the way it responded. I can say it's amazing how much difference there
is with low-end torque and high speed performance on a CVT. GoPowerSports has a performance CVT which
is better than the stock one sold by GasBike. The stock belt sent with the CVT from GasBike is junk and will
stretch on you. The GoPowerSports belt is better quality and GasBike is now selling them as replacement belts
for that transmission.
I am going back to the taller gear and I want to check into the Lifan engine/trans since I want to be able to pull
a trailer and it would be better with a multi-speed transmission on the bike for pulling a trailer. A trailer is a must
for going fishing next summer or getting lawn tractor gas. I want to get the weight off of the bike frame and the
3-gallons of gas is not good for it, not even the smell of in the trunk of a car. I've got all Winter to contemplate
what I'm going to do with the bike and this darn Winter is in the way.
Dennis
