This new and improved PK80 might be a good contender for 50mph with that 32T. With the jug being milled down and increasing compression should be able to spin some RPMs. Disc should be a good way to slow me down from that too!
the main thing is think safety, I've seen 50+mph on a bicycle and its hauling butt.... a lot can go wrong and if it does at 50mph its gonna get real ugly real fast.
I've retired my 50mph ambitions now that I seen it and experienced a blown out front tote tube about 30 minutes after hitting 52mph on my bikewhile it was just sitting in the shade cooling off after my fastest run.
That was my sign...... and I took the hint from that wee voice that said slow your butt down son....lol!
It was my fault though, front tire was a little soft and that allowed the inner tube to shift a little and the rim actually cut the valve stem to the point it blew off, first time I've ever had that happen on a bike and I think some of it was due to the fact that at 50mph the front tire was hopping a little from not being balanced good.
That bike has new Kinda Coniption tires and heavy duty tubes now, but with the current engine I have on it it only does around 40 so I feel much more confident that the tires and tubes wont be an issue now.
I had a flat one time at mid 30mph speeds and it was a heck of a ride getting the bike shut down without chewing on the asphalt, fortunately it was the rear tire and not the front on that bike but it was still very hard to control, so whatever you do don't cut corners on tires and tube for a high speed bike and take a small round file and file off any burs around the rim holes where the valve stem goes through the wheel.
