That looks sweet!
I have some work to do me thinks. I want to re-do mine with a step through frame.
I agree & an ebike makes it so easy to do so ...thing is, on clean smooth pavement I do prefer a hardtail as it cuts cleaner & with somewhat more sensitivity - but as "clean smooth pavement" is a mythical beastie 'round here, I've gone squishy w/no regret lolAt the speeds these things will travel a fully suspended frame is the best way to go.
Thanks Mike but sadly it'll look pretty crappy after a winter or two, which is one reason why I hadn't done the swap before. Just curious - but why a step through? Nothin' against 'em ofc, jus' wonderin' is all...That looks sweet!
Awesome! Defo gonna need a test fit though, I'm a bit over 6' and I can just swing a leg over this Haro, even a touch taller and it'd be awkward. I s'pose the 29ers have prolly accounted for that however else they'd have precious few customers hehnice ba. haro makes a great frame, my next frame will be a full suspension 29er
You should try changing your rear shock to an air shock. The rebound is a lot slower and it feels more stable during fast and sharp turns than my other coil shocks I'm using a Manatou air shock on my current bike and that bike handle really good on both paved or dirt trails especially since I moved my battery's location.Well, that makes a lot of sense Mike & in fact I really don't "need" full suspension on my beater commuter either, as I had it anyway I figured why not lol
TBH I'm developing really mixed feelings about the rear suspension as under "ideal" conditions (clean, smooth pavement) it's actually a bit annoying, even conceivably a bit less safe then a hard tail - in a hard, steep turn. As the suspension compresses from the lateral force generated in a turn the wheelbase length, steering axis angle & trail changes. It's ever so slightly but enough to notice, particularly as absolutely everything on this build is exactly the same as the previous - excepting the frame & suspension (& crankset, but that's irrelevant). So as all the moments, the weight & balance, tires & traction, everything being identical it provides a unique perspective to the pros & cons of a suspended, two wheeled street machine... it's not enough for me to revert to the hardtail, but it is something I'm going to need get use too.]
Indeed! Although for all the simplicity of Mongo the T3 makes up for in complexity - fixes fortunately rare, delving into the tribrid taddy's harnesses makes "nice" a very comparative term & puts such silliness as my previous panic in perspective lol... sometimes I need sit back & remember this, first pic doesn't even include the lighting & accessories, the second pic that schematic;LOL! Must be nice to just need a soldering iron and a multimeter to fix your ride...when it's not just some errant harness or plug that got disco'd, anyway
They truly are... couldn't really tell ya how many tire sets Mongo's gone through tho, as it gets the "hand me downs" offn my other rides when they're a bit too worn. Rear tires ofc wear faster & I've an aversion to rotating those to the front despite being a normal, even common practice - I jus' save the scabs for ol' Mongo, whom doesn't care s'long as they're round hehthey are amazing rides. i still have had no problems and on my 5th set of tires at least. great machines and great fun
Sorry for the misunderstanding Mike, I love regen braking - it's only that some folks don't (or jus' don't care) for assorted reasons & may not connect the feature, not realizing the potential safety hazard, even if only a comparatively minor one.What don't you like about regen braking?
You're right snellemin, replacement/upgrade would likely be the best option... but I'm a cheap, stubborn SOB that more oft figures if it's busted anyway - I can't bust it no worse by trying to fix it, might even learn somethin' along the way lolI had a failed throttle once. It would launch by itself and got worst over time. I just replaced with a new one that seems to be build of better quality stuff. Anyways, I also installed a throttle tamer to give me a smoother throttle. It basically adds an adjustable throttle curve and buffer.
Nice shot of the red EVG bike. I still have two of those brushed motors in my garage. Lots of torque out of those old things.
