I would go with 5 KW. You will still go fast like the wind. And get the flux vector controller with sine wave output, they are much better than hall device commutation.
Yep Vector is the way to go for sure.I would go with 5 KW. You will still go fast like the wind. And get the flux vector controller with sine wave output, they are much better than hall device commutation.
I would recommend the same. 5 kW is a lot of power, and too much will cause reliability issues for a daily rider especially considering your bikes rigid frame. Even 5 kW seems borderline as it is. Plus your range will be farther.I would go with 5 KW. You will still go fast like the wind. And get the flux vector controller with sine wave output, they are much better than hall device commutation.
The vector controller can be programmed with any cutoff setting you want to limit juice to the battery. I just don't want to caught underpowered cause I'm too lazy and too old to be doing any pedaling. My pedals will be to rest my feet on and that's about it. LOLI would recommend the same. 5 kW is a lot of power, and too much will cause reliability issues for a daily rider especially considering your bikes rigid frame. Even 5 kW seems borderline as it is. Plus your range will be farther.
The problem I see with this motor is that if you want to make the max 20KW power output you need to run it at 120V at 166A, that means you're going to need almost twice as many batteries as you planned for the other one running 72v at 100A, if you have $5k to spend on a bunch of batteries that can go puff if you do anything out of their operating limits, or cells start dying and overloading the other cells and making them fail prematurely, it could be quite an expensive learning experience.I had Brake Regen and my batteries loved it. My brake pads loved it well. I only had a single front disc brake and my Brake Regen is what actually brought me to a stop most of the time.
I guess I'll be gettin this 10kW of illegal magnetic goodness instead of the 5kW!
Thanks much.I'm just enjoying the banter. I don't exactly believe some of the HP claims, but seems like 5KW is pretty huge. 10KW? If you could pull that off, it would be really sweet.
And bike the way I do LOVE THE STYLE OF YOUR BUILDS!!
Tell us more about your brake regen.
Honestly, if I were you, I'd stick a slightly modded 212cc predator on that bike and enjoy it, you can muffle it to make it quiet and it will be cheap and trouble free for many miles.
Yeah I'll be using Kings Super Sprocket / Top Hat duo.Five will be plenty, trust me -
Don't forget that full torque is available at zero speed. You will be faster than any car off the line. Not to mention that 5 KW is continuous, you have 15 KW peak.
You better have a stout motorcycle type drive sprocket / wheel or risk ripping the spokes to shreds.
5/15 will be plenty.
You'll need the full 120V to get the max claimed power out of the 20KW motor, that means twice as many batteries run in series to get the voltage required.Actually my batteries are rated at (220A continuous / 275A for 10 seconds).
My electrical math is spot on this time. It's irrefutable.![]()
220A x 66V = 14,520 Watts. 275A x 66V = 18,150 Watts. That is called 3rd grade math.You'll need the full 120V to get the max claimed power out of the 20KW motor, that means twice as many batteries run in series to get the voltage required.
At only 60V, it would make 10KW at maximum current flow of 166A for that motor. Again, you should really at least buy a book on electrical circuits or electric drivetrains and read it, and realize that you can't pick and choose your own reality, specifications are what they are, and if you don't follow the guidelines and match your systems specifications throughout it won't perform as planned or at worse it will start killing expensive components. If you blindly go about buying stuff without researching thoroughly how the whole system will work together in harmony, it's gonna be a huge disappointment. Electric bike component vendors must love selling stuff to guys like you, bent on learning things the hard way through puffs of smoke and melted parts.
Facts of life, laws of physics.
Tires are DOT rated to 93 MPH, spokes are 11 gauge and the rim is a 18" dirt bike motorcycle rim. I used the Top Hat / Super Sprocket and it worked fine on my last bike but that's not saying a whole lot, so your guess is as good as any as to what is gonna happen. LOLSee, 5 KW with 15 peak will be plenty.
I see the top hat thing is supposed to bolt to the disk brake flange on the wheel. Is that flange a beefy heavy duty thing? Trust me when I tell you that that motor has enough torque to shred bicycle wheels. You might want to consider a moped wheel for the rear.
Brake Regen never fades. It feels like AntiLock brakes on a car and was much stronger than my hydraulic disk brake was. I rode my bike for months without Brake Regen so I know what it feels like with and without it. Brake Regen should be mandatory on all high speed / high amp controllers for its braking features alone.
