Well it never has run that great. I've never been able to give it full throttle under load.....at the time I thought it was just breaking it. It's always taken forever to warm up. It seems to just get worse.
I put the AF back on, decently oiled. Makes no difference.
I reset the idle to 4.5 turns as a starting point, but really it takes so long to warm up it's tough to get a warm idle going.
I'm running 30:1 oil mix, before that about 20:1 to 25:1
It has about 1 tank of fuel give or take on it.
The base gasket looks OK, how should I check it?
Would crank seals cause such a problem?
It seems to be running lean because I have to choke the heck out of it to get it to run, but sometimes when it dies it backfires nasty fuel spray. And the plus are always wet, and rather nasty with fuel.
