Arizona Dyno-Glide Build
Big Bill
117
arizona
Ok guys
I found a Dyno in Santa Anna California for $70.00 so I drove
out to pick it up ( 12 Hours round trip).
After looking through some threads ( Culvert City , Scotto, Head Trauma
, Venice Motor Bike and some others builds) I am ready to start a new build.
Making motor mount template and spreading rear stays using wood wedges.
Culvert City bolt in method .
[/URL][/IMG]
AGK's mini hub will be my front sprocket mount, I milled a 3/16" keyway
in the crank shaft and drilled 2 more 1/4-20 set screw hole in the hub.
[/URL][/IMG]
Big Bill
117
arizona
Thanks guys
I have gone though your builds o so many times, you guys build some
vary nice bikes.
I will be making more progress this weekend so I will keep on posting.
Here is the motor mount, 3/16" aluminum plate the center mount is tapped for 3/8-24, there will be 3 1" clamps on the motor mount plate.
[/URL][/IMG]
Until Sunday Bill
Big Bill
117
arizona
Hi Velodrome
I am thinking the same thing, that Chief you built is sweet!
I can't wait to see this up close that Twin you have is clean.
This build is going to take some time, lots of parts to make but when
I'm done I will meet you at the Pavilions or go riding or both. The Schwinn
frame snapped at the welds, some I will be using some of the parts
off it .
Bill
Big Bill
117
arizona
Well here's my progress for this week end.
Here is the front engine mount with plywood drive plate.
The start of the intake manifold yes I used 1/2" conduit with 3/16"
plate and drilled a hole big enough to slide the conduit through and welded
on the inside and out side with a big fan blowing the fumes away. I still
need to weld the carb side but I will wait until I have it at ride height to
make sure the carb is level .
[/URL][/IMG]
The engine plate is mounted with all 3 clamps, with the cranks installed.
[/URL][/IMG]
Happy riding Bill
Big Bill
117
arizona
Hey guy's Atomic is right I made these parts but if you look at
CulverCityClassic's Build on page 2 He has a link to some nice clamps
that don't break the bank.
Thanks for the complements Bill
atombikes
525
2
Northern VA
Big Bill,
What thickness are you planning to make your transmission plate?
I also have a Dyno Glide that I am building with a 79cc engine so I am very interested in your progress.
Big Bill
117
arizona
Big Bill,
Hi Atomic
I am using 1/2" Aluminum plate ( not bar stock ) I am working on the trans mount now, I should have pictures buy this weekend.
Bill
Big Bill
117
arizona
Saturday update.
The trans plate is getting close , when finished it will look like Culver City
but it will be pinned and bolted , Can't weld aluminum.
Drilled and tapped the case for a oil fill hole / a breather for a catch can.
[/URL][/IMG]
Modified the rear trans mount , this should take care of the trans plate flexing.
[/URL][/IMG]
Bill
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
25
38
Ridin' inSane Diego, CA.
Saturday update.
[/URL][/IMG]
[/URL][/IMG]
Bill
Looks great Bill......very beefy (^) This is the kinda stuff we eat, breathe and live for.....is it not? Fabrication makes the world go round.
dnut
runnermike
936
Sanford, FL
I usually don't pay much attention to 4 stroke builds since I am a 2 stroker, but something about this one caught my eye. Nice Work! I wish I had the means to fabricate like you, scotto, and culvercityclassic...!!!!
