Ok, sorry I've been away for a while, recently got flooded out to the max from a cyclone that went thru. Right, the SCR has a black side with writting on & the other side is (glassivated) metal. Looking at it with the black side with writting on it facing you, the lead out connections (left to right) are K, A, G. The tantalum capacitors are polarised. Look at them thru a magnifying glass & u will see a + close to 1 leg. The + must go to earth, as the timing network operates under a negative voltage, making earth positive in respect to the negative voltage. I'll have to go back & look at the schematic to see which jumper ur asking about, (I use a slightly modified variant of the CDI). I'll check & get back 2. Cheers
