modified cdi and cr 80 coil
Maybe we can all get together and do a group buy and have some blank PCBs professionally made by a board house?
I took the advice of Ivan H and lined everything up in vertical series on a solderable pcb board then ground off the non-needed areas with a dremel (to insure no shorting would happen). Worked great for me! ill try to get a pic of it for you.
Can I substitute with this SCR?
HERE
And is there any reason why I can't use switches instead of jumpers?
As far as the SCR I am not 100% sure, but it should work just fine. Now about using switches in the place of jumpers that would be just fine as long as they aren't small low current switches.
NOTE: DO NOT CHANGE THE SETTINGS WHILE THE ENGINE IS RUNNING, THIS MAY CAUSE DAMAGE AT THE TIME OF FLIPPING THE SWITCH SETTING.
That part, BT136-600E is a TRIAC, what you need to use is a(n) SCR.
But it's both!
(10 Pcs T0-220 Package Phase Control SCR Triacs 600V 4A)
So.......I ordered the wrong thing, I won't cry....th-th-this time.
Going to have to do some info digging I guess.
Your Right
TRIACs belong to the thyristor family and are closely related to Silicon-controlled rectifiers (SCR). However, unlike SCRs, which are unidirectional devices (i.e. can conduct current only in one direction), TRIACs are bidirectional and so current can flow through them in either direction. Another difference from SCRs is that TRIACs can be triggered by either a positive or a negative current applied to its gate electrode, whereas SCRs can be triggered only by currents going into the gate. In order to create a triggering current, a positive or negative voltage has to be applied to the gate with respect to the MT1 terminal (otherwise known as A1).
So the question is, can I put in a diode?
i have a 48cc skyhawk motor and my magneto and the bolt it is on broke and i dont know how to fix it
I suggest you make your own post with your problem under the 2 stroke section. More members are going to see your post. Furthermore, your topic is not related to the ongoing post.
Good Luck,
Chris
AKA: BigBlue
Can I ask what the difference is on what the original Jag and the modified cdi does?? Not very electronic savvy lol.
You have a little more adjust ability with the modified CDI and the JAG seems to be a little over priced from what I hear you get from the maker of it.
ok i have the jag unit and it crapped out after a couple of days.It took to long to get it and Living in Canada would have to ship it back etc and it is now spring. Can you fully expalain the more adjustability of the modified cdi? I see that the jag has 2 different jumpers for the advance and retard curves so 3 curves each. but this one has only 1jumper for retard curves. I am trying to maybe order the parts and get someone to help me with building one as my motorized bicycle has cooked a few cylimders with the stock one due to compression and modding etc. Thanks for any info provided.
With the modified, you can run the same settings as the "jag" but you can also advance timing if you choose (27ohm resistor jumped with 390 bridged out of the circuit)
IMO, if you don't fully understand the timing settings, the modified might be a bit too much.....coming from the guy that blew a hole in his piston by having the wrong settings :)
Hi, yeah, if u dont fully understand the jumper settings to select between the 2 variations u could easily over advance the timing. I have emailed the schematic for the stock Jag circuit & a simple vero board layout to a member & I'm pretty sure that he's going to draw them up on the computer &post them, I'll check back with him to make sure. If he's not I could email them to someone else to get posted, as I dont have a computer or know how to use one. Made on vero board & with quality components they are quite sturdy & I've made several for friends & none have failed. Cheers
Oh, & in regaed to substituting SCR's, if u do, even tho the substituted SCR may have the right or higher voltage & current handling capacity, it'll most likely have a different gate threshold characteristic, which means it'll trigger into conducting at a different time. It may not be much, but it depends on how different the characterists are. Stick to the C106D. They are cheap as, common as & were the origonal part in the KDX CDI the circuit was adapted from. Cheers
ivan can i ask if this modified cdi unit have higher voltage and current handling capacity,then do you think it can run two coils from the unit to two spark plugs ,or would the current handling fall to great and little spark to both then ?
To be honest, I'm really not sure. They do produce a hotter spark than the Chinese CDI/coil unit. I suppose the only way to know is to try it. Maybe if u could find a coil designed to fire 2 plugs,,, I know they exist but where u'd find I dont know. IIRC, there r 2 types of coils, rising field & falling field (maybe), so u'd need to be sure u have the correct type of coil. Apparently the CR80 coil gives the hottest spark of all the small MX types (very hot, will spark over something like a centimenter gap outside of the combustion chamber) so if u could find a twin plug coil with similar specs I dont see why it shouldnt work. I've always used the same coil off an old 500cc dirt bike wreck & it works really well. U could easily try parralleling 2 coils off the CDI to see how it goes. Good luck with & let us know how u go with. Cheers
thanks for your reply ,i used to use mick's cdi and cr80 coil before he sold it out to JAG ...I been playing around with a longer shaft to run two mag's but the magnetic fields are playing together, getting the thing to spark at the right time is a headache looked so cool and to my plan was then to run two mod jag cdi's retard a plug and avd one to the other plug .i was talking to Fred today and he has good ground and knowledge in how he runs two plugs with a 12volt battery gy6 scooter cdi with two coils and i think i will go this way cause i have had weeks of headache trying to come up with a two mag coil maybe still could but it is hard to know where it fires the second one being longer on the shaft maybe and the more rev's it gets worse anyway hope someday someone can nail this
