dracothered
Can any body tell me where to find 760 ohm resistors. It's the only part I can't find. Would a 750 ohm work? Thanks for all the info I'm looking forward to building this
The 750 would most likely work, but you can put two resistors in series that add up to 760 ohms. also you can measure the 750 ohm ones until you find one that is close to 760 ohms.
Remember the value is plus or minus 750 ohms based on the tolerance of the resistor. So if you have a 750 1/2w +-5% resistor it could be as low as 712.5 ohms or as high as 787.5 ohms.
 I have replaced my spark plug wire at advanced auto parts store. Made hide difference. More power. Better stars and using original Cdi. Along with speed carb and expansion chamber exhaust. It runs like a dream. It's a 80cc schwinn. 28 inch tires. For a road bike it runs great. But yes just replace the wire and u will notice huge difference.  Got a 38 tooth sprocket and high performance racing head for more compression on way and my performance upgrades will be done. Can't wait. Should go around 45 mph after that.
