(SNIP)
(SNIP)
Congrats scotto!
what size tap is that?
Interesting solution for the peddle crank arms. How well do you think it will work doing it this way? Could you have also done it by cutting part way through then bend and weld the crank?
Congratulations on the news, Scotto-!
Are you gonna hafta mess with that whole vent looking arrangement every time you check or change the oil? Looks like a pita compared to what used to be there.
(SNIP)
I know it will work very well, that's why I did it this way. You could use 1-1/8" x 3/16" flat stock for the same effect but the square tubing is stiffer and stronger.
And I wouldn't cut part way through and bend hollow chromoly cranks as you would never get the width you'ld need, it would shorten them alot and all the angles would be wrong.
(SNIP)
Do you think this type of peddle crank mod could be done with standard one piece cranks or would just heating and bending be the better route?
I actually did buy it, it cost me $20 but worth every penny. If people read the first post, they would know that I bought or acquired this mount and did not fabricate it. It's an incredible mount and wish that I made it.....I had the keen eye to know this mount was do-able.......almost perfect.
What is that you have between the mounts and the frame. Why is it there? Fill in space or shock absorption or protect paint?
$20 sounds pretty reasonable to me. Does your source have any more mounts like that for sale?
Where can we get those clamps?
In his first post he mentioned: "steveco55 (Steve) for the motor mounts"
If $20 gets you the clamps and mount plate, and if that is not the friends and family discount, I would probably pick up a set to save for a rainy day!
that blue paint is a beautiful color, to bad it had so many chips. i tried to touch it up with fingernail paint but my matching skills sucked to put it nicely. dennis
