Ludwig II; I took a look at that bike but I decided to proceed with building this one my way.
During the week I found an idler pulley that would work for my primary drive.
So I made up a mount and spring loaded tensioner to hold it.
I still need to fit the cable which will retract the idler allowing the belt to slip.
The mount also has tabs to hold a primary cover which is still in the planning stage.
My rear reflector arrived this week.
And so did my chainguard.
I was not too thrilled with this chainguard that I had.
So I found this one which is much more suitable for the Flyer.
Then this weekend, as the glue had set on the stack of boards, I marked out the first cut lines for the top gastank panel and started cutting.
