What engines are you building the frames for?
Are you including a mounting plate?
Will you have a frame at the race this Sat 7th?
MBR: The frames will come with a gas tank & motor plate for the HF 6.5 or 212. I am sure the smaller motors will also fit. It will be setup to use the CVT or jack-shaft.
I tightened up the seat tube by 2 inches today; the original plan was to not use a lay-back seat post. After some thought it would be wise to add the seat-post to the customers taste.
The bike is in the first stage of building so it won’t be at the April 7th race. But all my other ones will be....
CCC
The frame is on it's way, got the front section done and now moving to the back end. I like the way it is turning out.
One thing for sure it's not some chopped up bike frame that gets a big block added and a death wish to go along with it...![]()
ain't you got no job? sleep when you dead? wife wont let youin? nice stuff.
Give me a break Dennis...big thanks for the lathe...it’s a challenge but I like it...the shocks are sweet too...not sure if it will work on the seat.how come you dont have spider web's, flames and iron cross's on your stuff? it look's too old the way it is.
