harry76
I take it needs a shaft to go in the hole in end of the clutch shaft
I would also need to make a hanger/bracket to hold the outside plate on and actuator for the shaft, im starting to think its more trouble then its worth
And i believe the pin through the center of the clutch shaft pushes the pin (the one at 90 degrees to shaft) to take the tension of the clutch so it freespins, is that right?
then clean off surface rust and oil the surface. Voila, instant old parts, bolts ect.
20w50 or simlar is fine just dunk em in and wrap them in cling wrap
