	Wow, those bike stands are pricey! After using some stacked 2x4 cutoff a couple of times I put this together. If there was any real weight on it, I'd put straps or something between the legs. But it works good with deck screws holding it together.
edit- Looking awesome Holden!
Balancing from above Killer?
 Or just screw a flat bar into the wood over the stays, hmm, next time a bikes on there I'll try that. The pyramid shape is very stable.
 Or just screw a flat bar into the wood over the stays, hmm, next time a bikes on there I'll try that. The pyramid shape is very stable.Nah, I just rests on the chain stays. Can't drink around it, heh heh. If I had a couple of tire quick-releases, a clamp could be made easy enough. It'd need to be a couple inches wider to get at the nuts.Or just screw a flat bar into the wood over the stays, hmm, next time a bikes on there I'll try that. The pyramid shape is very stable.
/coffee-fueled-thought-process
 Had to take off my copper extension, wasn't running worth a crap. Got to find a better way to mount it to the shorty, or come up with something else. So the shorty's back on there now, and I tried to use the innards of a stock air box on it. Just the mesh and the plastic circle, but then it wouldn't go over half throttle. Took it off and it screams again oO that's a new one. Maybe the screws sticking through are holding the plunger down a hair. 2min with the hacksaw when I'm in the mood should tell me.
 Had to take off my copper extension, wasn't running worth a crap. Got to find a better way to mount it to the shorty, or come up with something else. So the shorty's back on there now, and I tried to use the innards of a stock air box on it. Just the mesh and the plastic circle, but then it wouldn't go over half throttle. Took it off and it screams again oO that's a new one. Maybe the screws sticking through are holding the plunger down a hair. 2min with the hacksaw when I'm in the mood should tell me. had to try the mesh/plastic first before I have to go buy some, and get 'that look' from the cashier... lols.
 had to try the mesh/plastic first before I have to go buy some, and get 'that look' from the cashier... lols.had to try the mesh/plastic first before I have to go buy some, and get 'that look' from the cashier... lols.
