Those are good questions Zean....as far as the handling goes, I don't know yet as I/we haven't ridden it yet as it is still not ready. As soon as I get the rear 22t final drive cog I will let you know.Excuse me scotto. I just finished a nice bowl of chili, 3 pieces of russle stover candy and two cups of taster's choice cofee for breakfast. I have a little bit of a stomach ache with headache, I don't know what's up with these headaches. I want to go out for about 5 hours on my golden eagle before my wife returns from work. The headache slows me down. I'm probably about your age with less than 1/10th your knowledge and experience. Your new tandem build is good looking. I think it has a lot of: power, reliability and comfort. How does it handle? Scotto I'm just asking because I don't know: does the new tandem build require a bracket from that 2'' round tube (off the middle of the rear seat tube) to the "u" shaped piece of steel on the back of the gear box that covers the 10 tooth output sprocket to stabilize the torque the engine exerts on the gearbox? I think you have done an excellent job of combining engine and bicycle to build something that gives us a sense of freedom hitting the open road. If it's appropriate for me to say: I think EZM is an excellent company and is blessed to have you and many others as dealers. Thankyou scotto.
And I must thank BarelyAWake for pointing me in the direction of these old Suzuki forks for the build here....they're perfect for the tandem, just need to find some rubber boots to cover the springs.
Thanks T......it's definetely a bicycle and a motorized one at that by all definitions. With the muffler installed it is so quiet that the cops aren't likely to even notice you......you could put a rack and paniers, tow a trailer and put a passenger on-board and cruise cross-country with ease on this bike.This is a great Post. When I see all of this post I think of how a person could take a cross country trip with this tandem. Only question I have is. What about the Cops. Lets say you are going 30 mph on this baby safely and There are the red lights. Is it a bicycle or a Motorcycle with no plates and registration?
I do like everything you did.
Thanks for Sharing.
T
Is that all you have to do? And here I thought some special tool was needed... I suppose you used one of those high tech hammers... ha! Thanks, Bill.SB,,,I changed the axle on my S/A drum hub (I cross-threaded the nuts and chewed the theads),,,the bearings come out easily
I removed the nuts that sit against the bearings and gave the axle a sharp tap,,,bearings came right out
they are just like the bearings in a skateboard wheel,,,
I hope that helped![]()
SB, I used a vice with padded jaws opened up to just wider than the bearing, rested the hub on the non-brake side, took a lead ingot and a special hammer and beat it into submission. They popped out quicker than snot.Is that all you have to do? And here I thought some special tool was needed... I suppose you used one of those high tech hammers... ha! Thanks, Bill.
SB
Thanks a lot for the information. Cutting the slot is a perfect solution and I'll do it. I did not want to try to dismantle that whole fork just to be able to fix a flat tire. This set up will be like what was on my 51 Schwinn springer fork. One leg's axle mount was a hole and the other a slot. Excellent. Your bike looks super!SB, I used a vice with padded jaws opened up to just wider than the bearing, rested the hub on the non-brake side, took a lead ingot and a special hammer and beat it into submission. They popped out quicker than snot.
To ease the wrestling of getting the 10mm axle to fit (wheel intact), I cut a drop-out in the right hand axle loop. Then install onto the left leg while compressing the right......get axle into position and gently let the right leg slide over the axle and BAM, install nuts and tighten to specs (crank'em down).
When I installed the 10mm axle I made a spacer that slides over the axle that sits between the bearings to keep them from too much side-load as the original axle does.....this is a pretty important thing to do. If you have questions about this, PM me. Hope this helps....gotta run.
scotto-
Thanks Silverbear and I hear you on the dismantling just to change a flat....that would be a nightmare. Just a little trick I use when changing flats while on the road....instead of removing the tire and wheel from the bike, just take the bead off of the rim on the most accessable side, pull the tube out and locate the hole and patch it. Check the inside of the tire for thorn or whatever caused the hole and remove it before slipping the tube back in and re-seating the tire bead and adding air.Thanks a lot for the information. Cutting the slot is a perfect solution and I'll do it. I did not want to try to dismantle that whole fork just to be able to fix a flat tire. This set up will be like what was on my 51 Schwinn springer fork. One leg's axle mount was a hole and the other a slot. Excellent. Your bike looks super!
SB
