I'm reversing some new Grubee GT5 motors, and found some nice metal surprises inside:
if installed un-touched, right outta the box, you could have some serious problems, including premature engine failure, lowered compression due to metal shavings gouging the cylinder walls and piston, and just all-around poor performance.
i'll post pics of the finished product soon, after i get some new nuts for the head. i ain't using those lousy acorns.
it's hard to tell from these pictures, but the head gasket was unevenly "torqued," but if you look closely, you can see it's crushed more in two opposite corners than the others.
it also had a different amount of washers under the crappy acorn nuts to take up the space. one had 2 flat washers and a lock, and the rest had one flat and a lock.
I had one that had a newspaper or magazine stuffed in the crank case. I have no clue why that was done, just to mess with us I guess.
Maybe one of the assemblers did not want to get caught reading on the job lol.
I also washed out the crank area with fuel/2 stroke mix to make sure to wash out any swarf.
Regards,
DaveM.
With the quality that these kits have nowadays, it is wise to disassemble and inspect your engine internals before use. At this point perhaps the vendors should start shipping these 'kits' with the engine completely disassembled. It seems that the buyer ends up taking everything apart anyway, so it would save us the trouble of initial disassembly, and maybe save them some labor costs of putting the engines together in the first place.
I have rinsed a few engines out that burned through the piston crown,
When California switched to oxygenated gasoline, quite a few folks never re-jetted their carburetors to account for the extra oxygen in the combustion process. Result: waaay too lean.
Anyways, I digress.
Rinse the cases out by mounting it up in a jig that will hold it up-side-down.
I just used rope wrapped around the engine and hung them from a 2x4 laid across 2 sawhorses.
The method I used for making a sprayer was complicated and over thought. It also used an air compressor which I know alot of folks here may not have.
A much simpler method is to use a small diameter hose attached to lid of an old (well rinsed) dish soap bottle or whatever you can find that will hold a decent volume and be easily squeezed.
Stick the hose way up inside the cases at various places , hold the bottle up-side down, and squeeze it. Be sure to rinse every surface inside the cases very well and collect the rinse product in a tub or deep drip tray. Do not let it drain on the ground.
I re-use it over and over. If you store it in a paint can all the junk will settle to the bottom and you can skim off clean solvent from the top.
