Hey guys!
Yes, maybe are differente engines, but the most of engines, the oil seal are thinner in the magneto side, i mean, the left side of the engine, it has near 4mm of thickness.
The part number on my high qual. seal it says 103393, but i think its made here in Portugal.
I use the same double lip seal, at the right side, and the left side. The left side, it only takes 1mm , and there is no such problem. The magneto connects easily, and the oil seal do their job.
The lower needle bearing, it needs a press, and some "high" instruments and machinery, and it is a thing that i dont mess with. If it has clearance, a new crank with rod is the best way.
There is two qualitys in the roller bearing, that connects rod to piston. The first quality - K10X14X13, it has lots of improvments over the original roller bearing, i use them in my 2x engines, and its perfect. It has also another roller bearing, the top of the qualitys, it holds more load, more RPM, and so on, and it is the KBK10X14X13, double the price, but its the best we can put on these little engines
cheers!
cheers!
