I've destroyed, erm torn apart...disassembled...(no no)... rebuilt 3 of these engines now, and from what I've seen they can be very different. Some people have a 15mm crank and others 17mm. I think the thicknesses on one were diff on one and the same on another, it depends
Thank you sir, I haven't had issues with seals yetas far as replacing them, so I'm not sure what the ngine I plan to upgrade will have in it, I will just wait and measure and go from there then, sounds like the best way for sure....thanks again for the help on this.
my troubles so far have been bearing failures, so wether or not I find the right seals or not I will be replacing the wrist pin bearing with the high quality bearing (K10X14X13-TV)
I've had one lower failure last year but it was a factory defect I believe, engine had maybe 15-20 miles on it and one of the lower needle bearing broke into and a piece came up through the transfer port and you already know the rest of the story.......LOL!
Thanks again LS614
