Thanks lol
Engine problems? Well... oddly not many
It's a "generic" 66cc and it's pretty much been jus' the same basic issues we all have, fasteners loosening from time to time (manly head, intake & exhaust) & that is ofc reduced in frequency (but not eliminated) with the use of loctite (blue) lock washers or nylocs (depending on location/heat), and ofc chain wear/stretch. I suspect the compression isn't what it used to be... but there's not been enough of a loss for me to care TBH.
The "worst" problems I've had w/it is my original NT carby was miscast and developed a hairline fracture (replaced fer less than $20) and I left it sit all one summer as I rode another build, during that time the bearing seal behind the clutch started weeping and contaminated the pads - I just cleaned it out thoroughly w/some carb cleaner and after some use, the seal miraculously "healed" itself and stopped leaking, after another cleaning the pads stopped slipping too
Other than that... tires... lotsa tiresl - tho I s'pose that's got nothing to do w/the engine's reliability lolz
Not that I'm suggesting or recommending it, but just FYI - the first 1500 miles or so I ran the thing on 50:1 Amsoil 'Injector' synthetic, then switched it to 100:1 Amsoil 'Saber' (mixed at about 90:1) - not tryin' to say that's why it's lasted so long... but it doesn't look like it's hurt it's longevity any heh
edit: missed the question of how I made the pads, sorry... they're jus' chunks of "black iron" pipe (typical thick walled mild steel) wthe same ID as my frame's OD, cut in half & ground down a hair to fit, then tack welded to the clamp;
