As for compression braking, I don't know how Flex is going to do that with a CC on the crank. I don't think it's possible, even with a locked crank freewheel.
There will times when you get down to the CC lock-up rpm, that the clutch will fall out and then you coast. You'll be able to pedal the bike as before.
However, anytime you are above the rpm of lock-up, you should have engine braking available.![]()
You go Phoo sounds like your having a ball..Me to been ridding the felt mostly
trying to break the shift kit so far cant everything is solid no movement or twisting ..also breaking in the BOXER WOW!!!!!!!!!!!
Just so you all know he is not answering because his wife used his laptop when she went to a convention and left the lap top on the ground forgot about it and drove over it with a car so he is with out a computer.
Terry
