Vfalpha-1
ok so i started out with a crappy bike some time ago and a Chinese engine i managed to fudge up , got blasted on here a lot for that one. i deal more with airplane engines than bikes though i have built some before. sometimes stupid things come out of my mouth before i think about it so bear with me. I was going to use a Schwinn point beach (red and white) for my build but i didn't want another cheap engine slapped on it so i decided a smaller more maneuverable 20 inch aluminum bike will do it took me 4 hours to find one that would work had to walk pretty far to get it too lol , since the engine i wanted to use is made for a pocket-bike it defiantly wouldn't fit in a 20 incher , not much would. so i used the rack from my Schwinn and cut the mounts down for the 20 inch wheel and mounted it to the frame originally it was to be just an electric brushed motor with pedal assist but the battarys vs the cost of an engine , i decided to go with a 54 cc big bore pocket-bike engine from a cag souped up to stage 3 the gearing will go through a small jack-shaft i made from a pocket-bike chain to the one that comes with the grubee (larger chain) both sides of the wheel have a free spin one is removable , which is the pedal side , the other is tack welded on , but it was press fitted so hard i dont think a full out acceleration could phase it. the motor comes with a 6 tooth sprocket im running to a 55 tooth then to a 10 tooth to a 16 tooth so a ratio of 19:17:1 from the engine to the jack-shaft then 1:60:1 to the 16 tooth sprocket (the 55 tooth is removable for different gearing) for a total ratio of 14:67:1 which is kind of high but it will keep the rpms down and i believe this engine can Handel it no problem blue is to the 6 tooth sprocket the red to the wheel . at 6000 rpm i should get an estimated 24.3 mph the engine has been clocked in at over 11,000 rpm (44.6 mph est)so she can haul if she wanted to but i will also test using gps the engine should be here in 2-3 days later on when i get more metal i will more than likely move this set up to my schwinn i ordered a manic mechanic hub adaptor just for this too , money spent so far 475$ lol nvm the big mess behind the bike , my room is my workshop my kitchen ect blah blah lol . most of the time its clean , till i start building
ps the rack is bolted on , and the arms are bolted to the rack , but im going to weld the arms to the rack and reinforce them via underside then painted a simmple silver to match the bike and prevent rust , may put on some hand made fenders
(edit) now that i think about it i can use a 68 tooth where i have the 55 for a ratio of 18:13:1 closer to the 18:75:1 that i wanted a 72 will give me 19:20:1 i think ill stick with the 68
