No Head Gasket Opinions
cory151
Just curious, as I noticed some people are running no head gasket for a throttle response and performance increase. Wondering what the guys who are doing this think of this modification.
Thanksdnut
It's not a good idea to run it without a head gasket... You will most likely end up with low compression from a leak!
If you really want to raise the compression?, Lap the cylinder & head down with some sandpaper on glass & install a new gasket. (don't go crazy sanding it down!!!)
dose any one knows how to take the magnet off to undo the springs ears on a pull start on a china motor were can i find a spring or can i make one any help will be thank full
I shaved down the head in a mill at work by .008" and done a neat job of it to try and bring the comp. up as it was starting to get tired and I didnt have the money at the time to get a rebuild kit and if anything made it run worse than what I started with (slant head jeez it had some warpage had to keep going till I got it flat).
Ended up buying a new jug, pis.,rings,head and it brought back the power it was beginning to lack.
Wrong place, wrong time buddy, and quit threadjacking.
You can use a less than paper thin copper headgasket (.005 in.), but I don't recommend running with no gasket at all.....as Norm said.
Well, I removed my head gasket, but not to improve performance, but to prolong my engine life. My aluminum gasket melted and bits of it went into the cylinder damaging my rings and the liner, the engine still runs but stalls after a few minutes or so. So I got me a new engine and removed the aluminum gasket, but I replaced it with a head gasket maker, the one you can buy in a tube or small brown bottle, so no leaks. Check out this thread:
http://motorbicycling.com/f34/ht-ideal-running-engine-temperature-15197.html
gaskets are called gaskets for a reason lol. i do not recomend not running one ore using goop to make one.
These are the thin copper gaskets that I use in my 46cc 2-stroke. The copper base gasket is .005 thin. The round one is the head gasket and seals the 15:1 compression in the combustion chamber. Always use some sort of head gasket unless you're an amazing machinist that can mill a perfect seal.....even then.
Hey if ya get no leaks bud good on ya thanx for sharing.
But yeah peace of mind I'd atleast do what scotto suggested if ur anything like me I'd be paranoid and checkin the damn thing after every ride but yeah each to there own.
I ran my old motor about 6500 miles with out a base gasket.It did make a difference,not alot,but some.You just have to make sure the piston doesnt hit the spark plug,and it changes the intake and exhaust timing slightly,but to no ill affect(for me anyway).
Vw air cooled engines do not have head gaskets since abandoning the copper rings in the '50s. Even turboed, no one needs them. They do use iron cylinders though.
I rather have goop that can get flushed out through the exhaust, than aluminum bits scraping my liner, damaging it and the piston and the piston rings.
I only put about a 1 mm diameter of the Gasket maker using a toothpick and put it around the surfaces, and that amount is enough to make a great seal. Been using for more than year with no leaks. Ironically, 3 engines that I have burned got head gaskets.
those vw's fit like a spiggot at 35psi and their are copper gaskets if you chose to use them. those funny deep sounding bugs are pulling the studs out of the case and that is the exhaust leeking out the alum. head that will be junk soon. years ago my friends funny cars always used copper head gaskets, fire it up 2 min. shout er down re-torque heads done. never no head gasket leaks but lots burned pistons holes in the blocks even running motors missing pistons and rods sometimes winning! cast iron block and head would sometimes need a sledge hamer to seperate them. i like copper gaskets!
these are a pin once you get it together there is a notch for the cable/rope after cable breaks then spin it around insert rope and let it unwind and gather rope up
