Depending on where (and when) you get it it all has ethanol. During winter mo's I believe all gas (in America) has ethanol. Ethanol in effect raises octane too and requires higher compression to properly burn. Some states require as much as 10% ethanol all year around. Most modern automobile motors are now 10:1 or better compression while our utility motors are typically no more than 8:1. BTW Ethanol is what's in a martini and one benefit is that it will allow water to pass through your engine as alcohol absorbs water while remaining flammable!
Best thing to do is buy good gas if you can i.e. Texaco, Chevron, Shell etc and avoid Arco, 7 eleven (Citco), BP etc. And, again, follow manufacturers suggestion.
I think (not certain) many of the smaller engines (25-35cc) are higher compression and spin faster too, if that's true, they would benefit from higher octane gas.
Cheers!
