Venice Motorized Felt Revolver!
Venice Motor Bikes
Here's my dream bike that I just finished building for a customer... A Felt Revolver. (Now I have to have one for myself!!)
This bike performed flawlessly on it's maiden voyage, a 20+ mile club ride.
I did a 'in frame' gas tank, custom 1/2" offset steel motor mounts, & I also hollowed out the muffler making it into a expansion chamber, (the engine loved it) It had tons of smooth power & it wasn't too loud.
Nice job AGAIN ! This in frame tank looks different then others I've seen.Could you ...would you talk alittle about how you did this tank.All the others I have seen have been cut and rewelded.Your method seem to be different?
nice build,,,as usual :)
I really like the forks on the slater ;)
(not the usual springer, they are for a threadless headset)
Hi Norm
I have to say this bike looks amazing some really nice touches to the bike. I have just one question where is the world did you get the fuel filler neck I have been looking for a quality filler neck for a long time care to share ???
Cheers
Terry
You know the last one with two rims in one was pureely just one out of box! ANOTHER BADA-S JOB! sweet bike again and again
That is a very nice Felt. Nice job on the tank also. The only thing that doesn't work in my eye is the whitewall on the rear, is there a reason for this? A black on the back would make this thing teets, honestly!
Nice build, cheers!
I've tested several products to seal the rear of the tank & I finally found one that worked perfect!! (I'm keeping it a secret for a short time) The rest is carefully applied JB weld & tank Kreem.
Nice build, cheers!
I kinda agree about the single whitewall, but thats the way Felt makes 'em. (but the look grows on ya!) :)
Revolver - Felt Bicycles
Thanks Norm, was just really curious about that, thought maybe the guy likes em that way;)
I also had a sneeky suspicion that TB would be gettin that answer....can't say I blames ya fer not lettin the cat outta the bag.....but when ya do! I really need to turn my fat alloy top tubes into tanks...looks so much cleaner. Cheers!
Felt Slater
Just finished this Felt Slater with SBP jack shaft and Nuvinci hub...only to take it all apart again to get the jack shaft kit powder coated. The ride is unbelievably smooth with very little vibration. It cruises comfortably at 25-28mph (according to a cateye wired speedo). Still working on a couple of upgrades including a front dynohub drum brake. Here are a couple of pics of the almost complete bike...
Re: Felt Slater
Sweet bike!!
Do those Nuvinci's have hand brakes, or coaster brakes???
Re: Felt Slater
Sweet bike!!
The Nuvinci uses a hand brake -- disc or roller. I went with the roller brake mainly b/c you don't need an adapter to use it on a felt frame. Also, it looks cool and seats right in inside the dropouts. It seems to have plenty of stopping power.
I've only run 50 miles on the bike so far, however, the difference is unbelievable. To be able to cruise at 25mph with the motor just over a hum (on flats) as well as start from a dead stop without pedaling is unreal compared to a traditional set-up. I highly recommend it.
