sportscarpat
Time to throw my hat into the ring on the clone engine builds.  I have been quitely working away on a new personal build using the 6.5 hp Honda clone engine as a power plant.  This build is an evolution of the current chassis design used on my Racer and WZ builds, and will use most of the same components, but the engine and drive system will be completely new.   These engines are right around 200cc so that is where the "Sportsman 200" name comes from.  I have to give credit to Lurker, CCC Jeff, and Cobrafreak John for paving the way with running the clone engine cylinder in the upright or vertical configuration.  Once I saw that and the running clone powered bikes of CCC and Shane of AGK I knew I had to have one.
The build has been progressing along and here it is in it's current state still resting in the frame jig covered in brazing flux. Good old turn of the century brazed and lugged frame design.
Sportsman 200 by Sportsman Flyer, on Flickr
This is a close-up shot of the engine mount tacked into place in the frame and the engine mounted up. Engine is running centered in the frame to maintain an overall balanced package. I tied the mount into the seatpost frame tube, the bottom bracket housing in both vertical and horizontal directions to reduce potential twisting moments, and then into the down tube. I ran the engine base parallel to the seat post frame tube giving the engine cylinder about a two degree forward rake in the frame.
Here is a detail shot of the finished engine mount assembly and the mock up I used to test fit to the frame. Mount is CAD designed and laser cut to insure accuracy, then placed into the frame and squared up off the frame jig to assure proper chain alignment. The three pieces of the mount are tabed and slotted together so they self align and interlock before welding. Very easy to assemble and maintain alignment through the tig welding process. I like how the main backbone of the mount looks kind of like a big bowie hunting knife. I will try to keep this thread updated as the build continues.
