Who else always pedals?
Discussion in 'Motorized Bicycle General Discussion' started by virginian, Aug 11, 2010.
  1. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    Did you use the gas reserve? I only foudn out about this a week ago :O
    I though by reserve it meant control the amount of fuel going out
  2. motorbiker
    motorbiker New Member
    Mar 22, 2008
    569
    When I was a kid going fast meant pedaling hard and I guess that is the way my brain works.
    There are many books on how to bicycle fast. Right frame for your size and gearing and all.
    Add an extra motor and something else happens.
    When pedaling the motorized bicycle the human motor becomes one with the gas or electric motor. :)
    usflg
  3. Buzzard
    Buzzard Member
    Jul 9, 2008
    263
    I set up the gearing on my bike and it pedals pretty easy for a motor bike. I can extend my pedaling trips a lot farther than I used to just pedaling. Knowing when I'm all wore out I can fire it up amd ride back home with no effort.
    buzzard
  4. virginian
    virginian New Member
    Dec 19, 2009
    117
    When I asked the question, I meant pedaling while the motor is running instead of pedaling without a motor.
    I have tested how much pedaling adds to speed by getting to a constant speed on the flat and then stop pedaling and then start pedaling again. When I stop pedaling my speed drops within seconds and then increases when I start pedaling again.
    I usually cruise at about 28-29 mph in the open road. At that speed normal pedaling adds only about 1 mph and hard pedaling (not sustainable for more than a few minutes) adds about 2 mph. That is not much, but as I said, I like to pedal.
    But pedaling really helps on big hills. I tested one big hill hitting it at 35 mph at the bottom. I slowed to 13 mph at the top with no pedaling and 24 mph when I really hammered the pedals.
  5. motorbiker
    Mar 22, 2008
    569
    It's fun too !
    I have always loved engines ! And I love teaming up with one like this !
    The nearest connection a human can have with a motor, that I know of, is when pedaling a motorized bicycle !
    I am still getting a handle on it. :)
    usflg
  6. Buzzard
    Buzzard Member
    Jul 9, 2008
    263
    What's your pedaling cadence at 30mph? (strokes per minute) and what gear are you running in? That's got to be some fast pedaling.
    buzzard
  7. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,250
    I take my bikes out that have no motor. I enjoy the silence and the work out the ride is nostalgic every time. That's where my old world began. No motor guaranties a work out.
  8. virginian
    Dec 19, 2009
    117
    My cadence at 30 mph is about 90 rpm. 80 rpm is optimal for a good cyclist, but 90 works if you don't have to apply a lot of pressure on the pedal. That's why I tend to keep speed just below 30 mph - which is really fast for a bike!
    My chainwheel now has 48 teeth. I replaced the 42 teeth chainwheel that the bike originally came with. The freewheel has 11 teeth. I replaced the original 12 teeth freewheel. I constantly ride in the highest gear (48/11) except when starting from a full stop or going up a steep hill.
  9. scotto-
    Jun 3, 2010
    6,527
    Try that with a single speed, thems what I ride. If I tried to pedal with the motor, my cadence would be about 200+ with my 36/16 gearing.....and that's the other reason I need not pedal!
  10. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    I used to be a real die-hard pedaler (I'm still anti-cager for the most part!) but then I moved to a flat state with mean winds that quickly humbled me and my 12 mile commute. That called for a motored Schwinn Cruiser Seven with a 52T front and 11T 7th gear. Drive sprocket on the HT66 was easily-changeable 34T Rocket Ring on custom mount. 30MPH with a useful sweatless cadence for me and a PDQ commute! I think a motored bicycle is truly optimum if the assist comes back around. You'll accelerate much quicker and get better fuel mileage from my experience. All about the gearing on both sides.
    That said, not everyone is able to set their rides up that way. My new ride still needs work on that part. 16-17MPH top speed in 3rd gear!
  11. klb6154
    klb6154 New Member
    Jun 20, 2010
    76
    ok im a large man 260 lbs w q 66 cc on a ten speep and in fifth gear on the steepest of hills i only help the motor @ about 75 rpms at the cranck @ the most never tried a harder gear cause my shifter is in a hard to reach[ when riding] position if my bike drops below 15 17 (mph estimated as i have no speedo yet) i have to help to keep it in the powerband but only on steep hills and little effort is required
    #31 klb6154, Aug 14, 2010
  12. Allen_Wrench
    Feb 6, 2010
    2,787
    I have a hybrid motorbike. It runs on coffee in first gear, and fuel mix in second gear.
    lafflafflafflaff
  13. Tim_B_172
    Tim_B_172 New Member
    Aug 26, 2009
    251
    I built this thing so that I wouldn't have to pedal. I'm a gear-head* not a bicyclist. Although I do have to help it out on steep hills.
    *I'm a gear-head that loves working on anything but cars. Airplanes, motorbikes, DIY wind turbines, tractors, but NO CARS. ;)
    #33 Tim_B_172, Aug 14, 2010
  14. Goat Herder
    Apr 28, 2008
    6,250
    This is starting to sound like Motor biker singles addslafflafflaff
  15. Tim_B_172
    Aug 26, 2009
    251
    Did I mention that I also love long rides on the beach? ;)
  16. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    On the way home tonight, I stopped and put my pedal chain on the big chain ring so I could pedal more.
  17. K-dregg
    K-dregg New Member
    Apr 20, 2010
    78
    I dont flap my arms in a airplane or make swiming motions when in a boat and i do not pedal my Motorized bike either.:) I do a lot of regualar bike riding, both road and MTB.. so not having to pedal is a nice change..
  18. stingray'04rider
    stingray'04rider New Member
    Jul 3, 2010
    34
    second motor :)
  19. stingray'04rider
    Jul 3, 2010
    34
    that actually makes me wonder: are there women on this site? because i bet there aren't many.
  20. scotto-
    Jun 3, 2010
    6,527
    Why? They don't have to pedal if they don't feel like it! It's like riding a tandem for them.lafflaff
    And yes, there are a few and I mean no offence...
    #40 scotto-, Aug 19, 2010
