What do i need to know to replace my spark plug?
Discussion in 'Motorized Bicycle General Discussion' started by Murph, Jun 7, 2011.
  1. Murph
    Murph New Member
    Jun 3, 2011
    28
    What do I need to know/do to replace my spark plug? I'm not sure how they're sized / what factors to consider so it fits my bike. My bike is a 48cc 2-stroke, but i don't really know specifically which one.
    The current one has a screw-bit on the top of it, but I think that newer ones have a ball thing, right? That'd be better?
    I'd probably want to go to autozone / advance auto parts and pick it up. I'll also need a new wire.
    I know there's a million threads on plugs, but most are like 'which high perfomance plug is higher performance' and now 'plugs for noobs' :)
    Thanks!
  2. jototojo
    jototojo New Member
    Apr 10, 2011
    32
    Its really easy, just go and by an NGK spark plug bp6hs, i have this, and you just unscrew the little lid or cap that the new one has.
    To take the old one just pull the Spark Plug cable (Black), and unscrew.
    Simple.
  3. Murph
    Murph New Member
    Jun 3, 2011
    28
    Do I need a spark plug socket to get the old one out, or can it somehow be done with a wrench or something?
  4. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    There should be a silver tool that came with the kit. One side is for the plug, if not a spark plug socket and a ratchet will do fine. 5/8" or 3/4" depending on the spark plug.
    Personally I'd change BOTH the spark plug and the ignition wire/boot. To remove the ignition wire, turn out of the CDI (counter clockwise).. to install reverse operation. Use one with a wire core (not from a late model car). Lawnmower shops will have this or you can rob one from a old lawnmower.
    #4 Al.Fisherman, Jun 7, 2011
  5. kolomootro
    kolomootro New Member
    May 24, 2011
    62
    there are spark plug sockets if you have one i would use it.it would be easier and not as prone to causing damage like a wrench.i hope im answering the question lol
  6. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    Before you change the sparkplug, make one last full throttle blast down a flat road, kill the engine, then pedal home. Make sure your engine is stone cold, before removing the sparkplug. Install new sparkplug.
    Now look at your old sparkplug. Is it black, brown or white around the electrode? If it's brown, leave your engine alone. If plug is black or white, then carb tuning might be in order.
  7. Murph
    Murph New Member
    Jun 3, 2011
    28
    Thanks for the tip! I suppose I'm alright, then.
    [​IMG]
  8. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    That's a nice, brown, chocolate color. Looks like your carby is tuned real good.
  9. 5-7HEAVEN
    Aug 2, 2008
    2,364
    Yes, I agree. The plugs looks good.
  10. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    Yeah, looks so good I'd just leave it in there.
    Just clean it up a bit with some carb cleaner and put it right back in.
  11. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Don't fix what ain't broke. That plug looks great. Leave everything alone. It doesn't get any better.
  12. 5-7HEAVEN
    Aug 2, 2008
    2,364
    My old plug looked just like that when I pulled it. I had two new ones, so I installed a new plug. Then I kept my old plug as a spare.dance1
  13. Pilotgeek
    Pilotgeek New Member
    Apr 6, 2011
    403
    Dang. You could probably save that picture and use it as a "this is what you're aiming for" example.
  14. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    I will tell you what Murph. Looks like your spark plug is fine. When I replaced my spark plug, I went to a motorcycle shop, showed them my spark plug, and just by looking at it they found a compatible plug. One difference between the stock plug and the new plug was the hex size. A different hex size doesn't hurt anything as long as everything else is the same. But the different hex size meant that the kit supplied spark plug tool no longer fit. A buddy of mine gave me a spark plug socket, so I'm good to go.
  15. Murph
    Murph New Member
    Jun 3, 2011
    28
    Thanks for all the advice, guys :) Glad to know my carby is working well!
    I got a plug from the auto parts store and it fit great.
    I'm keeping the old one around as a spare - I mostly needed to change it because it had the 'screw' on top instead of the 'ball' and the spark plug wiring i could find wouldn't fit it well!
  16. Pilotgeek
    Apr 6, 2011
    403
    FYI, you can screw off the "ball" end.
  17. Ernst
    Ernst New Member
    May 28, 2011
    363
    Thanks for the thread!
    Is it really true the cable unscrews out of the cdi????
    It looks like a one piece unit so I went shopping for a cap only.. found one but I'd like to change the wire..
    Ordered two NGK spark plug bp6hs' so I'll have one in stock if needed.
    The plug that came with the motor has what I call a bobble head instead if a screw on cap. Why?
    The retaining clip came off and so the bobble head is free to fall off the plug.
    I hope the NGK's are quality.. Oh well maybe I can find an old plug with a screw on head and rob that top.
    #17 Ernst, Jun 10, 2011
