DuctTapedGoat
When i put the chain tensioner on the bottom, the thing is not sitting straight. How could i bend it to make it fit the chain right?
Here's a few suggestions.
Find a way to make it work on the bottom! When you're not moving, it looks like your slack is at the top, but when you're riding, all your slack is at the bottom of the chain - which is where you want your tensioner. You don't want your tensioner to be taking the brunt of all the torque right out of the motor, it will not stay where you want it to be near as long as if you had it on the bottom.
The purpose of the tensioner is twofold. Not only does it let you adjust for roughly 3 links worth of chain tension, but it also keeps your chain aligned as it guides onto the driven sprocket - make sure that alignment is good!
Your drive chain being standard bicycle chain is a MAJOR issue! I would very very strongly suggest getting some 410, 415, or some #41. The links are wider and deeper - so you'll really have less problem with it coming off the chain and gives you some side to side play in getting the rear chain alignment proper.
Remove the tensioner, remove the pulley. Put the pulley on backwards, and reverse the bracket's bolts. Put it on now as it looks like it normally would go. This will move the tensioner without angle, and you can end up getting a very clean 1/4" or so of chain direction.
Remove the tensioner, remove the pulley, and take JUST the plate. You can bend the plate to put it where you need it to be if reversing isn't enough. It's strong stuff, so I'd suggest a table vice. BE CAREFUL - you don't want to bend it so much that the pulley won't roll, and you don't want it bent to the point that your chain is cutting into the walls of the pulley.
