Tony01
Specs
Wheelbase: 55”
Weight: 170lbs
Battery: LiNMC 22s1p 80v 48ah Tony battery 150amp continuous, 3900wh. LVC: 66v, HVC: 92.4v
Motor: QS205 3.5t 14.4kv
Controller: Nucular 24F, uLight module
Charger: Modded Huawei R4875G 93v50a 110/220vac
Frame: custom tube. Mostly .065” wall mild steel
Forks: Suzuki K10
Rear shock: DNM 190mm with chain travel limiters
Wheels: 17x1.4 36h, 70/90fr 80/90rr Michelin
Brakes: Yamaha 120mm fr drum, 203mm rear disc, variable regen direct drive rear hub.
Charge plugs: J1772 adapter, AVC2.r com module, 110v female plug for sharing J1772 or charging 110v with double male cord.
Controls: Right: Throttle, front brake, rear disc brake foot pedal. Left: variable regen throttle, horn, turn signals/hazards
Speeds
Top speed: 86mph (MAX) 76mph (limited)
Speed on empty @77v: 70mph
Voltage range: 75-90v, 3.4-4.1v per cell
Battery amps: 285a peak
Motor amps: 480a peak
Charging 110v: 2000w, 2.5-4 hours full
Charging 220v: 4500w peak, 45 minutes full
Range: 35 miles at under 65mph
Previous build Worlds fastest schwinn cruiser
Next build 1973 Honda CB500f
Been working on this thing a couple years now.
I first drew it up, then built it, then sold the two halves of the battery. I had planned on running a 20s2p of 48ah cells which would give me 72v96ah. But I ended up selling a bunch of those cells as 20s1p or 72v48ah. Great cells. One customer ran out of money and told me to keep the pack. I sat on it for months thinking what I would do.
I planned to run a huge battery then got some other cells with super ratings. But I could not fit them in this frame. I gave up on the frame pretty much. But one day I was rummaging in the metal scrap pile and came upon this 5x5 aluminum box tube. I found if I squared up the battery, it would barely fit. And the box tube barely fit in the frame I built. Well it looks like it worked out.
The 3D pic is after many reworks. I drew the frame completely then started over again many times. But this one is very close to actual. The built frame “tank” area is within 1/8” of the solid.
I had the computer out near my fab area and used angles and lengths to set my tools. This thing was a big job and I even screwed it up when I did that batt box the second time. But I’m going to run it. Done with it, just want to get it on the road.
Built the swingarm the other day. I didn’t draw it cause I didn’t need to. I used the same tube as headtube for the pivot. It is 1.5” OD and 1-9/32 ID or standard schwinn numbers. 1.281” ID. Found bearings that fit without machining. Used a 1.5” hole saw to make the washer ends and stuck them on.
I originally planned to use an aluminum swingarm. I machined a mild steel pivot mount for it with a 12mm ID. Mounted the swingarm in the mill on an aluminium surface plate. Cut the dropouts straight. But then I realized I made a mistake with the dropouts and wouldn’t be able to make it work. Then I decided I would go half inch for the pivot. Luckily I could thread the 12mm for a 1/2-20 and run grade 8 bolts in half inch bearings. So that’s what I did. So if I need to, later I can run the alu swingarm. Just need to ream with a 12mm because the crappy tap I used probably formed the threads a bit. I drilled and tapped some 10-32 set screw holes just in case.
The last couple days I fabbed up plates for my swingarm pivot. I need to slim the mount down 3/8” per side before mounting the plates for the pivot mount tube. Got most of the stuff cut out. After this is done I will have to decide how the shock will mount up. There isn’t much space because of the way the batt box is oriented. The shock can be in the swingarm as pictured, or it can be parallel to batt box with an A-frame on swingarm for the lower mount.
Definitely my most difficult build. And my first and last trellis tube frame. This is hard! Getting so sick of building my own stuff. I could draw stuff in 3D, and pay somebody with better tools to make it.
