scottcason69
Can anyone tell me what's.the fastest anyone has gone on a Chinese 80cc motor on a bicycle
There is no Chinese 80cc motor speed record and there never will be.Can anyone tell me what's.the fastest anyone has gone on a Chinese 80cc motor on a bicycle
i unofficially hit 62 on the same bike drafting a truck using my phone gps, and then it blew up.
You blew up the phone or the motor? At that speed, you must have been spinning over 9000 RPM or better, really straining the structural limits of the materials the rod, piston, wrist pin, crank & bearings. If your motor blew, it's probably because something came apart internally.
At 30 MPH, my motor vibrations are so bad it shakes like a titty dancer on meth, everything in my mirrors becomes a blur. (gotta stuff my handlebars with lead shot, I know) At those speeds I'm not so much afraid of wrecking or spilling at speed (although I'm sure it'll hurt if I do), so much as the motor grenading between my knees.
I hear...er ah feel ya Dave!! 39 M.P.H. was my top speed going down a hill 32 level
Dave as i bet you already know 90% of the vibe is coming from loose motor mounts, I had one mount vibrate out and the vibration was ten times worse so after I fixed it & I went over the other 3 bolts and glued some rubber tubing inside the mount as well as the saddle clamp.
I got on it , got up to speed and it was sooo smooth hardly any vibration at all . Still feels like its gonna fragment between my legs though at top speed!~
There are additional methods available to reduce vibrations in a China Girl, which is one of the biggest limiters of RPM & speed, such as internal balancing. Most of us reading this do not have the equipment, knowledge base or skill set to do this ourselves. You might take your motor to a reputable machine shop with experience in 2 strokes or just purchase a prebalanced assembly from Dax, Arrow or CR Machine. Some have reported varying degrees of success by lightening the piston by drilling holes in it. But unless you have experience in rebuilding motors, I wouldn't recommend it, as it is far too easy to remove too much or cut the wrong location, resulting in a junk engine that will never run again. I tried using a lightweight titanium wrist pin & I can report that while it did ease vibrations, it didn't last, the titanium alloy used turned out to be too soft, it deformed within 10 miles & resulted in internal damage. At present, I'm awaiting FedEx to deliver me a new top end kit that I bought last week.
I did 53mph on gps with a 24" schwinn on 34T sprocket......this was 2 years ago.....same setup![]()
53KPH maybe, that is 33MPH and possible for a direct drive 24" wheel.I did 53mph on gps with a 24" schwinn on 34T sprocket......this was 2 years ago.....same setup
