Thread for alternative engines
There is a handy thing to know here, I don't know about local regulations in other countries. If an item for repair/service/cleaning/whatever has not been collected within 3 months of being made available, it can be sold for no more than the cost of the service provided. I know a place that has a load of stuff uncollected, and I think, if the engine for the big bike project isn't any good, I'll drop in and see what they have lying about.
Bought a horizontally opposed twin motor a couple of years ago, It turned out to be a 2 x 139cc engine off a 12hp air cooled Whizzer outboard motor.
Talked to friends here in Fl, was told they were a common motor here. The motor use`s many of the Available Whizzer parts. Have been thinking of listing it on Ebay. Have many front and rear Whizzer wheels that I plan on using with the belt drive.
Roncvlt1
Could you post a pic of the 12HP engine?
Thanks
Jim E
Just in passing, the PA50 Honda. Made from proper metal to real engineering standards.
images
Russell
Should have pics to resize in the external Trigg HD. Am a bit layed-up, will get to it asap.
We corresponded a few years ago ??? Thinkin I had questions about how you did your build??
Will take new pics if necessary,
Ron
A stand alone unit, and you can even pivot mount it tensioned against a spring like a Mobylette to take advantave of the vario belt drive. I think they're overloked in favour of more "sporting" types, but they have a lot going for them.
Had 2 sold a PA50 last summer at swap meet. Still have one that has a 50 in it but the engine stand upright. CVT trans. should be a good power plant. It should save a lot of work when i go to build a bike with it..............Curt
This is quite interesting, a French company making copies/substitutes for Mobylette engines.
http://www.lamobylette.net/moteur/m...eav7av88av894050etccylindreairsal-p-2094.html
Translated via Google:
"ENGINE COMPATIBLE mopeds MOTOBECANE AV7. AV88. AV89. 40. 50 etc. AIRSAL cylinder [MOT002586] € 186.04
ENGINE COMPATIBLE mopeds MOTOBECANE AV7. AV88. AV89. 40. 50 etc. Cylinder AIRSAL
Click to enlarge
ENGINE COMPATIBLE Motobecane mopeds SOLD WITHOUT DRIVE IGNITION NI NI CARB.
ENGINE INCLUDES:
- 1 CARTER NEW ENGINE WITH BEARINGS AND SEALS NEW SPY
- 1 CRANK NEW MADE IN FRANCE
- 1 CYLINDER PISTON BRAND AIRSAL (AV 7 2 TRANSFER CYLINDER WITH FIXING THE PIPE ON ADMISSION WITH 2 CYLINDER VIS)
fat transfer modeling improves cylinder fins standard or square (make selection below).
2 studs fixing the pipe.
- 1 NEW HEAD (POSSIBILITY TO HAVE A PLACE IN THE HEAD PHOTO, ONE HEAD NEW MODEL WITH FIXING THE AXIS ALIGNMENT WITH THE ENGINE GASKET HEAD AT THE SAME PRICE SPECIFY WHEN PAYMENT..).
- SEALS NEW ENGINE (HEAD, EMBASE, CARTER, SPI)
Please select the available options and the desired amount for this product:
Shape of the cylinder: "
Given it's designed to take Mobylette parts, it's probably just the engine unit the French want, as the electrics are a, simple and reliable, b, easily replaced by a range of suppliers. It may well be the thing is designed as a base unit for their moped racing.
I have always been fascinated with WW1 fighters. And like Snoopy, wanted to fly my Sopwith camel against Baron Von Richthofen.
The radial engines would look so cool as an in-frame mounted engine and be perfect for a cent. clutch. Just found one at wallyworld. $3K +, lol
The flywheel effect would actually be an advantage.
http://www.walmart.com/ip/7-Cyl-260cc-4-Stroke-Gas-Radial-Engine/40523122
Wally world has some really cool engines but crazy expensive; http://www.walmart.com/search/?query=gas engine&page=2&cat_id=0&method=related
.fly
.cptr.
!!!!!! How cool would that be!!!! LOL
Dangit Lud! Now I wanna do one.
(Not bad enough to blow $3K USD/4K euros(?) on a "just for a goof" mower. Except I really do, snork)
