It's off the net. And it's a 16hp iron block with a roller bearing crank. NOT a 4hp. Lol!
I wish I still had one of these. Flat. Out. Indestructible.
I have some real good memories of the engine that made me look this pic up for another thread. Check out "Gearhead Memories" In tavern
Now that i look closer the cover is bigger,not seen a red one that big. I had one sold it they are sought after for garden tractor pullers,they get like 60 hp out of them. I have 4 case garden tractors that have 12 & 14 hp in them,will be down sizing on them also only need one good one...............Curt
I wonder why you don't hear about no Harley frames breaking? You see those engines dance all over in the frames and they don't break! I think its a little more due to either cheap frames or bad mounting!
there's a Huge difference between a well engineered frame and a backyard hack with a rubber hose trying to call it a mount... have you ever seen how tough these Harley frames really are? we're talking about tubing with 1/8" to 3/16" wall thickness and the head stock is closer to 5/16" wall thickness, The older ones used forged headstocks welded into the frame tubing as well as forged mounting pads for the engine and transmission. I got an old Ironhead frame at the shop that's stripped all the way down and that thing is Rock Solid. You can definitely feel the difference between a *** cruiser and a Harley on the road as the Harley is just as solid as it can be and makes everything else feel like a toy.
Being a fellow Harley rider I'm sure you already know this, but this is for the newbs that want to point out Harley rubber mounts their engines... Yup, they do now, but until Very recently All their engines and transmissions were solid mounted with the exception of the Dynaglides. The Sportster finally got rubber isolation mounts just a few years ago, but I really like my solid mounted sportster myself. Even the sportster frmes are tough as nails and weigh twice as much as most Japanese cruiser frames.
Nice 4 hp Kohler,got one just like it ..................Curt
If ya can't hang with a little vibration, Buy a factory built motorcycle. BUT NEVER RUBBER MOUNT YER ENGINE, It dont really work.
We all tried rubber mounting when we were newb's, unless ya found this site BEFORE ya started yer build. It just kinda sounds like common sense to rubberize the thing to quite vibration. WELL, I didn't find this site for a few years after I started building. I did figure out that soft rubber wasn't the answer, so I tried using tire sidewall rubber which worked a little better. I still couldn't figure out how to make it ride as smooth as a Honda. Then I found this site and the answer is, IT WILL NEVER RIDE LIKE A HONDA,Cause its a not so well balanced Chinese 2 stroke. Some run smoother than others, but they all are gonna vibrate to some extent. GET USED TO IT, or buy a Honda.LOL. sometimes after riding for an hour or better I can't feel my balls anymore and my arse goes numb too. I try to take a break before my hands go numb because it's just too dangerous if ya cant hold on to the bars.If ya can't hang with a little vibration, Buy a factory built motorcycle. BUT NEVER RUBBER MOUNT YER ENGINE, It dont really work.
fatdaddy.![]()
Exactly right. My first 6 china girl motors were smooth enough to enjoy a long ride, but then I got 4 in a row that shook terribly. Rubber mounting didn't help. I was building them to sell but wouldn't let them go like that. Finally I learned how to balance the crank/piston assembly and got one to smooth out nicely. I still have a couple of kits left and I'm afraid I'll eventually have to balance them as well.
The only place I still use rubber is under the gas tank, and thats mainly just to keep it from sliding around. I rubber cement a strip to the top tube then rubber cement the tank to that. It dont move at all.
fatdaddy.![]()
