abracadabra
I forgot to include that i had a couple failed attempts before i realized the value self tapping screws have in assisting mounting applications.
The difference between your concept and the one used by most is that the rubber is not between the engine and the frame. Your mount more closely duplicates the resilient mounts used in automotive and motorcycle applications whereby the mount fasteners are not directly subjected to the vibrations. Not perfect but better than sticking rubber between the engine and the frame. Glad it is working for you.http://motorbicycling.com/album.php?albumid=1702 upoaded a pic of a application that works.
Look carefully.
See the white pad between the mount plate and frame under the Ubolt?
Notice the flattened frame tube? Caused by overtightening to try and stop inevitable engine movement caused by rubber.
Notice the visible distortion and damage on the chunk of downtube still visible?
Also notice the damaged area (paint worn off where engine rubbed) clearly visible on the broken section of seatpost tube from VIBRATION causing ENGINE MOVEMENT.
DON'T USE RUBBER OR ANY TYPE OF COMPRESSIBLE MATERIAL IN YOUR MOTOR MOUNTS.
*Wipes spittle off monitor screen*
How did you get the photos to go up, all my photos are online incompatiable as I have a HTC one m8. Super nd photos and standard.
High quality .
" Plus some removed characters(removed to show link instead of pic)
